4020 cam and oil pump sources
JD Jack
11-29-2004 21:30:24
I have a 66 4020 diesel. I am having the motor rebuilt by a local mechanic. He just started taking it apart, and found that the cam gears are worn, so it needs to be replaced. Also he figures the oil pump is bad because the presssure was low. Is John Deere the only source for these parts? Also, I have heard that the cam off a 4240 will work in this motor. Will it? Does it have any benefits for power, or cold starting?
4020dt
11-30-2004 20:12:48
 Re: 4020 cam and oil pump sources in reply to JD Jack, 11-29-2004 21:30:24
If you have the big injectors you have a 1964 , < 91,000 . 1965's 91,000 > had the pencil injectors which I personally don't like , but that's just me , I have a 1964 Powershift , turbo and some other stuff . My 4020 as well as several others around here have the 466 cams in them . Takes a litle doing but it works .
twopop
11-30-2004 06:05:11
as I remember,the 4240 used a crankshaft driven oil pump whereas the 4020 oil pump is camshaft driven,therefore you cannot use the 4240 camshaft in a 4020.you will need the block number to order a new camshaft.I get shafts from abilene machine inc.1-800-255-0337.you can also get complete rebuilt oil pumps.john deere will supply the parts needed piece by piece.
G/MAN
11-30-2004 10:50:20
 Re: 4020 cam and oil pump sources in reply to twopop, 11-30-2004 06:05:11
Earlier 40-series 466s (including the 4240) used the cam-driven oil pump just like the earlier 404s. Later in production the crank-driven pump came into use. I don't know the engine serial number break the change ocurred at, but there are both early-design cam-driven pumps and late-design
crank-driven pumps shown in the parts books. And the crank-driven oil pump engines still had the oil pump drive gear machined into them because it was used to drive the mechanical tachometer. At any rate, you're correct about the camshaft swapping, as different part numbers are shown for the 4020 and 4240. Apparently some of the early 4020 engines used a different single gear held on the cam with 3 bolts, while the later engines and 4240s used a 4-bolt cam and a dual gear made to drive the front-mounted injection pump.
JD Jack
11-30-2004 18:39:47
 Re: 4020 cam and oil pump sources in reply to G/MAN, 11-30-2004 10:50:20
Chances are that I can not use the 4240 cam then? My 4020 is a very early one, althoough I have never checked the year. It has the big injectors, which I have been told were only used on the oldest 4020s. Are any of my assumptions right? Thanks for your help!
G/MAN
12-01-2004 07:36:02
 Re: 4020 cam and oil pump sources in reply to JD Jack, 11-30-2004 18:39:47
Not knowing what the actual differences are, I'd suggest using the cam that is called for in the 4020 book for your specific tractor. Possibly the lobe specs and timing specs are different for the two cams. I don't have access to the numbers and can't say for sure. Are you considering using a used cam? I'd get a will-fit cam from an outfit like Endurance before using a used camshaft. Even a Deere cam will only be in the $400 range with lifters.
