70/720/730 question
Sponz
11-29-2004 19:59:45
Im not familiar with the two lunger"s and i was curious... is the rear end and tranny any heavier built in the standard opposed to the row crops?? I didnt figure they were but i just couldnt help asking.
If this seems like a really stupid question im sorry Sponz
F-I-T
11-30-2004 06:56:39
 Re: 70/720/730 question in reply to Sponz , 11-29-2004 19:59:45
The 70 "Series" was unique for Deere at the time in that they used the same row crop chassis for both the standard and row crop models. Tranny and rearend was the same, just wheel and front axle equipment differed. There might have been a rear axle housing difference, but nothing in the gearing.
HTH
Frank
RalphinWI
11-29-2004 21:51:23
I don't know the answer, but I doubt that they are heavier. With the generally smaller tire, all parts of the transmission would be turning faster (for the same engine and ground speed) and hence be able to transmit larger amounts of power. One criticism of the standards is that they put in very long hours in the same working gear and hence tend to have noisier transmissions. My father-in-law once broke a quarter in S.D.in the teens or early 20's. Hired someone to plow from 6 a.m. to 6p.m., while he took the night shift from 6 to 6. At times he allowed the Huber(?) to take its rein, while he walked, since it was cold. If I remember the picture it was a two bottom plow. I also met a person at one time that ran 1 or 2 quarters with a John Deere H, which ran around the the clock.
Ty
11-30-2004 14:56:10
 Re: 70/720/730 question in reply to RalphinWI, 11-29-2004 21:51:23
The rear axle housing is all that I see differant between the two.
RalphinWI
11-30-2004 07:52:13
I took a quick look at the A, AR parts manual. Looked like the changes were in the transmission, adding one cog to the driver and removing one cog from the driven gear on going from the late A to the late AR. I can check more carefully if you wish.
