49 B Heat Shield
JB
02-10-2004 09:05:43
My 49B all fuel was converted to gasoline. Parts manual shows a heat shield under the gas tank on the gasoline only models. Do I need to install a shield if I run gasoline only?
Clooney
02-10-2004 13:39:58
 Re: 49 B Heat Shield in reply to JB, 02-10-2004 09:05:43
JB, a lot of those all-fuel tractors were run on gasoline without that heat shield without any problems..
~I wouldn't worry about if for general use but you might need one if using a mounted picker, or long hours of field usage in real hot weather..
~As long as you don't hear the gasoline boiling when you stop, or gasoline fumes venting heavily from the cap you won't have any problems..
~The newer gasoline doesn't boil as easy as the gasoline form the 40's & 50's so that helps..
[email protected]
old
02-10-2004 11:02:39
I have a 35B that is all fuel but has been run on gas most of its life and we have never added that part, you will probalby be ok unless you have a major gas leak. And if you had that I think you would see that before you started it up
