Dubuque Transmission Chatter?
Henry J
02-10-2004 09:01:23
I got spring fever and am thinking about how I am goint to solve my last mechanical challenge with the 420 restoration. This has been a working tractor in the past.
Problem: It has a nasty chatter/rattle/gear lash noise when running in 5th gear. The noise shows up when running free (not pulling or deceleration).
History:
This same noise has always been there.
I have had to put another ring and pinion set in. The noise was exactly the same with the broken up set of gears as the replacement ones. I put good replacement spider gear bushings and shaft in the differential when I had it apart. The lash was set to JD spec but I used the old cone angle shims from the replacement pinion shaft/gear.
I have had the trans completely gutted to check all the gears, bearings, preload, and end play according to the book. Bearings that didn't look good were replaced in the process.
I have a different set of 5th gears on hand which I will probably put in for grins when I have it apart again.
Currently I have the trans with final drives still installed sitting on blocks. I am thiking that I will try to put the trans in 5th with the shifter removed and run the input shaft with the 1/2 inch drill in hopes that the noise will show up. This will have to take place when the temp gets up to allow for free turning of the gears. I have already drained the oil to get rid of that drag.
I am wondering and suspecting that this kind of noise may be coming from a final drive considering how noise travels.
Any ideas or thoughts out there while I am waiting for the Robins to show up and the snow to stop blowing? I would appreciate any in input or ideas. Thanks
silverado1
02-10-2004 17:40:57
 Re: Dubuque Transmission Chatter? in reply to Henry J, 02-10-2004 09:01:23
Henry J,
Whats the weight of the oil that you are running in that transmission. The best thing that I have found to silence noisy gears is to run thicker oil. I don't know what the book says but I don't see any reason why 140 weight oil wouldnt work. Its just a thought. Good luck
Josh in Indiana
Clooney
02-10-2004 15:36:51
Henry, that classic gear clatter or rattle is pretty normal in a the high gear ranges of straight cut gear transmissions.... In most cases it's caused by a slight amount of play between the gears & bearings, gears & shaft splines, & wear on the bearing surfaces of the counter shaft & related gears, & power impulses..
~Usually gear whine, or gear howl is caused by worn gear tooth crown or gear mis-match.. Gear mis-match or excess gear wear usually shows up as load or decel noises..
~Noises at no load or float are usually gear slop, bearing slop, or a stack up of gear play..
~In a lot of cases the viscosity & stickiness of the gear lube can have a big effect on the gear noises at low load conditions. The modern thinner gear oils don't cling to the gears as good as the old straight mineral oils & allow more to noise to develop..
~If all your gears & bearings are known good & the shafts have minimal wear at the bearing contact areas that's about all you can do.
~Other contributing factors are engine input pulses [pretty bad with a 2- cylinder] & drive shaft dampening.. Those 420 clutch plates were dampened with spring hubs & if the springs are weak or distorted or the splines are loose that can transmit shaft & engine harmonics into the trans & excite the gears under certain conditions.. I put a 40-C clutch disk in my 40-S & that increased the gear noise significantly due to it having a solid center clutch disk.. In some of the newer trucks & automobiles we put dual mass dampened flywheels on the engines to decrease the gear rattle at some load & engine speed conditions. .The thinner the trans gear oil usually the worse the gear rattle..
~I'm wondering if you will even get any gear rattle if driving it with a smooth electric drill & no long drive shaft..
~If you are wondering if your noise is coming from a different gear set or final drive area just try to match the gear noise to a RPM range. If at engine speed it is definitely in the trans input area,, if at or about wheel speed it's in the final drive area,, if at PTO speed it's probably in or around the mid trans area...
~Hope you can find it but it probably wasn't that quiet even when new..
[email protected]
Henry J
02-10-2004 17:17:03
 Re: Re: Dubuque Transmission Chatter? in reply to Clooney , 02-10-2004 15:36:51
Clooney
Thanks for the shout back. I was not aware of the clutch disk effect on gear lash and chattering. Come to think of it, I did run across something interesting in the clutch when I had it apart (It has not been run since then). The 11 inch disk had been installed with the large rivet heads facing the flywheel (backwards). The tractor had been run until the rivet heads and the flywheel worked it out and the flywheel had a nice big groove that the rivet heads cut into it. I did replace the clutch disk. Bet that sounded interesting for a while!
I will post back, but it will be way down the road
buickanddeere
02-10-2004 10:37:40
Are all the gears from a matched pair that have always ran together or have they been mixed and matched from two different pairs? Isn't 5th direct drive on those? Is there now some unused gear(s)free to rattle or rub against something in 5th? I was a little slow figuring it out in time for my 435 but any slant dash 420,430, 435 and 440 will take the much beefier ring and pinion from a JD model 1010 prior to serial number 31,000. Still available new from Mother Deere. If your 420 have inboard finals like a "W" row crop utility the 15% slower gears from a JD 1010 post 31,001 will bolt right in.
Henry J
02-10-2004 12:06:03
 Re: Re: Dubuque Transmission Chatter? in reply to buickanddeere , 02-10-2004 10:37:40
buickanddeere
The ring and pinion is a matched set out of a 435. Any other gears I can't vouch for. The extra set of drive and driven/slider gear for 5th that I have on hand are a matched pair from another tranny.
The tractor is a W (row crop utility)
Yes the noise does sound like it could be gear teeth clacking together. The shifting forks have been measured against another set of know ones to work and they checked out exactly as far as distances moving between detents.
When it gets loose enough to run up with the drill, I plan to shift the trans in 5th with the shifter assembley and then raise the assembly off and look inside if the noise can be generated.
