Casting Paint
walter squires
11-29-2004 09:32:10
Would John Deere buff primer sealer part # TY25618 work for the inside of the castings, I will have the castings baked.
JGC
11-29-2004 19:47:37
 Re: Casting Paint in reply to walter squires, 11-29-2004 09:32:10
You didn't say, but I assume this is inside a trans or rear end. I'd be very careful what I used. If it flakes or peels, you could plug an oil passage or bearing feed channel. Most castings I've seen that have an inside coating use the reddy-brown colored 'paint'.
JC
F-I-T
11-30-2004 07:06:33
 Re: Casting Paint in reply to JGC, 11-29-2004 19:47:37
Red Glyptal is used by many folks, but if the casting is dead dry and clean, any good quality enamel paint would work. I'd pre-clean it with a spray down with lacquer thinner.
I've used to use yellow JD because it made the inside of the casting so nice and bright to work in. It makes a huge difference in the reflected light that you get in there.
