4010 Gas Oil Pan
Hoosier JD
11-28-2004 17:45:31
My oil pan has what seems to be a yellow coating...not paint on the inside. I have never had anything inside of an engine painted or coated. I ended up wire brushing and washing it to get it ready to put back on. Has anybody ever heard of this? Doesn"t seem right to me.
Bob
11-28-2004 18:20:59
 Re: 4010 Gas Oil Pan in reply to Hoosier JD, 11-28-2004 17:45:31
John Deere paints the oil side of castings with an oil-resistant yellow coating. This prevents any pinhole oil seeps, and encapsulates any remaining foundry sand or debris, to keep it out of precision parts, and prevents rusting.
Hoosier JD
11-28-2004 19:25:48
 Re: 4010 Gas Oil Pan in reply to Bob, 11-28-2004 18:20:59
This coating was crumbling, and as I said before, I wirebrushed it out. Should I see JD and replace it? Or is there an alternative coating, or maybe just go with the bare metal? Thanks, Mike
Bob
11-28-2004 19:49:42
 Re: 4010 Gas Oil Pan in reply to Hoosier JD, 11-28-2004 19:25:48
I DOUBT Deere would have a replacement coating, but it wouldn't hurt to ask.
The casting could have to be VERY clean and free of oil for a new coating to stick, you might have to literally BAKE it to burn the oil out of the pores in the cast iron. I think most people would just get the pan as clean as possible, and free of any loose coating, and install it.
There have been other posts about this, and the trade name Glyptol is mentioned. You could look that up on Google for more info, or check with a local industrial coatings distributor for a material to use for this application, if you decide to pursue recoating it.
msb
11-28-2004 19:49:11
Mike,Deere uses the same coating on transmission and clutch housings too.Not sure Deere even sells it.I know they didn't used to.If you plan on running the engine every few weeks or so,I would not worry about the missing coating.The engine oil should keep it from rusting.If I had your address there at Pendleton,I would stop by and have a look.I can't be more that a few miles from you.You close to any of the Filbruns or maybe Jim Van Osdol?Did your bearings check out?
