I opened up the crankcase on the B tod
Kurt_JDB
11-28-2004 15:48:21
I recently purchased a "51 model B. This is my first tractor. I don"t know much about the two cylinder engines and have been somewhat concerned by all the tappet noise, blowing a puff of smoke at start up, getting a little handfull of oil/water/gas out of the petcocks, and how the engine seems to run on only one cylinder half the time when at no load slow idle.
I checked the compression (cold) and got exactly 95 lbs out of both cylinders. I checked the tappet adjustment (cold) All four were right at .020. I opened the crankcase cover expecting a greasy dirty mess. The inside of the crankcase looked absolutly clean. I tried to shake the rods around and they seem very tight. (would slide side to side)
All this seems real good to me. Would like to know if these specs seem normal, and what else I might check. Guess I was thinking I would need a rebuild, but now I"m not so sure.
Kurt
JD-Tractor
11-28-2004 17:29:49
 Re: I opened up the crankcase on the B tod in reply to Kurt_JDB, 11-28-2004 15:48:21
sounds like a great tractor if it's not broke don't fix it ! ! I opened up the crankcase on my B six years ago when I bought it just to see what was there and both nuts on the # 2 rod were just finger tight ,apparently that way since 1951 didn't hurt a thing ,enjoy
Mike M
11-28-2004 16:01:14
Everything you described is all perfectly normal. You normally don't need to use the petcocks on one of those but if you do stuff will come out.Tappets are very noisy compared to other types of tractors so while I cannot hear yours I suspect it is normal.Your compression is a little low if you have a gasoline only model I seem to think 125 lbs check when warm and make sure you open the throttle all the way and no choke to let air in. Miss at idle,that's why some call them popping johnny's. I wouldn't tear into it just yet,bottom line is if it will do what you need to do not burn enough oil as to foul out the plugs and not put out a lot of blow by.If you could run it on a dyno you will find out the true condition of it.
