RUSTED HOLE IN FUEL TANK, ON MY G....HELP
Ben.So.Tex.
11-28-2004 15:37:37
I am restoring a modle G 1949 I was sanding the fuel tank and notice some rust pits on the tank, when I sanded over them I made about 6 pin hole in the tank, How can I fix this? Epoxy them shut or what about a tank liner? and how do you install tank liner? Ben...
Duben
11-29-2004 08:07:45
 Re: RUSTED HOLE IN FUEL TANK, ON MY G....HELP in reply to Ben.So.Tex., 11-28-2004 15:37:37
I took the tank from my G to a radiator shop. They repaired the hole, boiled out the tank and coated the inside.
John Van Valkenburgh
11-29-2004 04:48:19
Most motorcycles shops have this liquid tank liner. The most popular one is called KREEM. It comes as a kit with 3 bottles. The first solution cleans, the second one etches and preps and the third one seals.
I've used this before with an old Allis Chalmers CA. Worked great. I recall coating the tank a couple of times with a day or two in between coatings.
If you pick up a copy of Hemmings Motor News you will find all sorts of ads for companies that make restoration products. Interesting reading.
John
1953 Model 50
Tractor James
11-28-2004 18:00:29
Ben this co. has it as I just coated my floats with it , ordered it on line with no probs. Nice folks to deal with
Mike M
11-28-2004 16:05:44
If it is clean inside I would lightly sandblast the outside to clean it and them solder it with acid core solder,then clean and paint it.I would also look close at the fitting on the bottom and resolder it if it shows any signs of being loose.
Ben.So.Tex
11-28-2004 16:16:57
 Re: RUSTED HOLE IN FUEL TANK, ON MY G....HELP in reply to Mike M, 11-28-2004 16:05:44
Mike like I asked the Gman, Where can I get this tank liner from? thanks Ben
Mike M
11-29-2004 06:10:54
 Re: RUSTED HOLE IN FUEL TANK, ON MY G....HELP in reply to Ben.So.Tex, 11-28-2004 16:16:57
The best tank liner you can buy is called Red Kote do a search of the archives on this site. I posted all the info about it awhile back so it would be stored here for everyones use.
P.S. If you would happen to also have a leak around the bottom fitting where the bowl goes on any tank liner will not hold up as it will also crack and still leak.These will still need to be soldered first.
jacksun
11-28-2004 17:33:35
there is a company called eastwood that makes car restoration supplies that has it or most major auto supply companies.
thejdman01
11-28-2004 16:45:10
i dont know how handy you are w/a oxy acetylene but you could braze if you knew how have brazed many holes before on rusted tanks just make sure there arent any fumes inside.
Garland
11-28-2004 15:56:55
Ben clean your tank as best as you can, if you acid dip it you could make the pin holes worse. Clean tank out as best as you can and order a quart can od tank liner POR has a good product also they have a cleaner you can use prior to putting the tank liner in. when you get the tank clean pour in the liner liquid and shake and roll tank around to get all surfaces covered then drain off excess and let dry for about 72 hrs. and recoat,this stuff dries pretty quick so the excess you drain off the first application you should seal up remaining sealer for the second application. On the first application it will seep thru the pin holes but will seal them off,the second application you shouldn't see any seapage hope this helps . Gman
Ben.So.Tex.
11-28-2004 16:07:50
 Re: RUSTED HOLE IN FUEL TANK, ON MY G....HELP in reply to Garland, 11-28-2004 15:56:55
Thanks Gman. I was think about epoxy then shut and then installing the liner.. Where can I get this tank liner stuff from? Ben
Garland
11-28-2004 16:34:21
 Re: RUSTED HOLE IN FUEL TANK, ON MY G....HELP in reply to Ben.So.Tex., 11-28-2004 16:07:50
Ben the tank liner is called POR-15 Fuel tank sealer order P-FTRK repair Kit1-800-3219260. Their internet address is www.tptools.com need any farther info yell. Gman
