755 PTO TROUBLE
glenn
10-23-2003 16:17:03
I just purchased a jd755 ,And i cant get the pto to operate,I seems to be an electrical problem,any one have a scematic or had this problem before?? Thanks in advance. GLENN
glenn
10-24-2003 12:40:53
 Re: 755 PTO TROUBLE in reply to glenn, 10-23-2003 16:17:03
Thanks for the imfo,My manual is on order. My hydrualic preshure is good and all other things are working.The pto light never comes on the fuse is good but there is no power to the fuse on either terminal.The lever is under my leg is in the pto/tractor position. The pto never turns. It`s sounding more like an electrical wire that is broken. GLENN
ChuckW
10-24-2003 13:31:07
 Re: Re: 755 PTO TROUBLE in reply to glenn, 10-24-2003 12:40:53
don't forget that there is a safety switch under the seat...maybe it has gone bad...if switch is bad then pto conection will be broken when you raise up in seat. You cannot run PTO without being in the seat. As I recall this is a push type switch to maintain the circuit.
ChuckW
10-24-2003 10:59:45
Glen, I restored a 755 a couple of years back. F.I.T. is right on target. There is a solenoid device that holds the pto in place and this also activates a switch to the clutch. My thoughts are fuses, or damaged wiring. You can get a manual from John Deere. I'd do that and check out thoroughly, don't leave a lot to chance to cause damage as those 755 parts will definitely eat your lunch.
F-I-T
10-23-2003 16:47:02
Glenn:
I helped a fella a while back work out the pto not working issue on his 855. The schematic in the service manual is pretty large (couple of pages).
I'll chop and splice that reply in here so if something sounds odd, it's probably the editing.
From the manual:
It's a mechanical clutch pack that is held in engagement with 120 psi hydro pressure. So if will not turn a load but only turn itself, it could indicate a worn or slipping clutch. Is it turning full speed in the no-load position, or is just spinning in sympathy to all the oil and gear spinning around it ?
BUT, that said,
I have a few ideas that are cheap to try. The pto lever swings an electro magnet that holds the pto lever in engagement. When I bought my 855 used, this wire was damaged and the pto magnet would not hold the lever.
So, first, if you are on the seat and engage the lever, the light lights up, and then you stand up, you should hear a loud "clack" as the magnet disengages and the arm falls away under the dash. If this is not happening, you may have lost power to the magnet because of a blown fuse, or a bad under seat switch. If electrical, you could hold the pto lever in place and see if the attachment runs ok. If so, you have an electrical problem. If not, you'll have to have the pressure checked, warm, at the plug at lower left corner of the rear-end. You'll need a book and some fancy fittings. If the pressure is ok, then the clutch pack is suspect, and that is a big job. I can't see that this clutch should ever get worn out with only 25 hp going through it. If pressure is low, you can add shims to bring it up.
I assume all other hydro functions are fine. You probably already know that the seat switch can be pulled outward, and the seat left tipped forward so that you could run a generator or an auger with out having to stay on the seat. This a good place to start to your testing.
Finally, check that the engagement lever behind your left calf) for the front, back, or both pto's is in the proper position.
Frank
MD
04-26-2004 16:31:14
 Re: Re: 755 PTO TROUBLE in reply to F-I-T, 10-23-2003 16:47:02
I have to replace the center pto for a 755. I have never done this job before . It is bent . any tips?
