HURRAY Got the clutch driver off the 720 (QUESTI
Billy Ben
11-28-2004 06:58:07
Used a clam shell puller to get the driver off. As ther were no jacking bolt holes.Got a new clutch driver(no holes) bearing washer, bearing and bearing retainer. My question is which way does the washer go in? Convex side in or out. Thanks for all the help in the past!!!!
John Van Valkenburgh
11-29-2004 05:20:21
 Re: HURRAY Got the clutch driver off the 720 (QU in reply to Billy Ben, 11-28-2004 06:58:07
The clutch driver can be a real dog to get off. I'm surprised that there were no 1/2" holes to bolt into. Perhaps its an aftermarket driver?
I replaced the bearing in my clutch last weekend. I don't recall there being a convex washer though. Just a flat washer, bearing and a convex retainer? Perhaps you ment the retainer? I put mine in with the convex side out. Hard to explain without a picture. I took a lot of pictures of my clutch rebuild. If you like I can email you the picture of how I put in the bearing, or if you like I can mail you a CD with all the pictures of the clutch (lots of pictures).
I also drilled and tapped in a grease fitting on the bolt that the clutch lever pivots on. This lever has a bronze bushing that was worn out. I replaced the bushing and the grease fitting should help keep it from wearing as much. I've got pictures of this too.
Best of luck,
John
1953 Model 50
mike brown
11-28-2004 08:46:28
Great! What was wrong in there? I've got several two cylinder John Deeres and they all have the holes for the jack screws. I'm surprised the new one does not. You might want to drill and tap a couple now so it can be removed easier down the road. Make sure to grease the ends of the clutch dogs when you reassemble.
