JD 1070 Clutch Problems
Sam Cobb
11-28-2004 06:46:16
The clutch will not disengage the engine to allow transmission shifting. The clutch was working fine the last time I used the tractor. I have left it out in the rain for a few weeks without use and now I can't shift gears. I don't know much about this tractor, but was wondering if anyone had any advice before I load it up and take it for repair.
Mike M
11-28-2004 16:22:26
 Re: JD 1070 Clutch Problems in reply to Sam Cobb, 11-28-2004 06:46:16
Try the below method first. If that doesn't work then try a method I used from the N board. You should be able to start it in gear if the safety swith is in the clutch if not you may need to bypass it for now,but hook it back up later,Get it going in a low gear then shift trucker style let off the throttle then shift up then accelerate keep the clutch pedal held down the whole time so it can break loose if it will once you get going a good speed high is good hang on to the steering wheel and be prepared for it to jerk to one side and need counter steer push down on one brake pedal only not both.Do this in a wide open area push the brake easy at first to get the feel of how it pulls you then stab it harder and I'll bet within two or three tries your clutch will be free.I did this on a model 850 JD with great success saved the guy hundreds if not thousands the JD dealer would of screwed him out of just for a stuck clutch.If this works and I think it will adjust your free play and cut a block of wood so you can block the pedal down when you park it again.
Sam Cobb
11-28-2004 17:07:53
 Re: JD 1070 Clutch Problems in reply to Mike M, 11-28-2004 16:22:26
Thanks for the info. I tried the first idea today and couldn"t seem to get it to free. I can"t start the tractor without having it in neutral, so I guess I need to disconnect the mentioned safety switch. Once started, I can only get it in reverse and first, second in low. Neither is fast enough to get a good jolt. I will try the second idea tomorrow. Thanks again, Sam
Mike M
11-29-2004 06:15:35
 Re: JD 1070 Clutch Problems in reply to Sam Cobb, 11-28-2004 17:07:53
Just do this in an open flat area and be prepared for when you stab one brake hard it will give a good jolt ! But this is exactly what they need.
Bob
11-28-2004 07:40:44
The lined clutch plate is likely lightly rusted to the flywheel or the pressure plate.
Try blocking the clutch pedal "down" for a couple of days, as this may loosen it. While the pedal is blocked down (engine "OFF"), put the transmission in "HIGH", and, with the aid of a helper "rock" the tractor back and forth as hard as you can. Sometimes, this will break it loose.
For some other ideas, go over to the Ford "N" board and type "stuck clutch" in the search box at the top of the page.
The bottom line is that if the clutch stuck while the tractor sat unused, most likely, there is no damage to the clutch, and it will be OK with no tractor split needed, if you can break it loose.
If it is not working due to a bad bearing, worn fingers, or a plate that's come apart, a split will be needed to fix it.
