General engine rebuild question
Plant Doctor
11-28-2004 06:03:41
I am rebuilding a Ford V8. It was professionally bored and honed and I received new pistons and rings from the jobber. Packaged with the pistons and rings was a "Rapid Break in Dry Lube". The directions say to wash the cylinders with brake fluid. Then apply this dry break in lube to the cylinder walls until they turn a light green color. I have never used a break in product before. Any information about these "Dry Rapid Break in Lubes" would be appreciated. Thank in advance.
BushogPapa
11-28-2004 09:13:18
 Re: General engine rebuild question in reply to Plant Doctor, 11-28-2004 06:03:41
If I have a freshly Bored Block, and it is for ME, I wash the cylinder walls down with parts cleaner to get ALL the oil out of the metal, and Rub liquid Dupont Teflon on all the surface of each cylinder wall...then if at all possible, I warm the block to 150 to 200 degrees to "Bake it in".. NEVER have had to replace any rings in any of them... Ofcouse, I do change oil regularly.. I break them in with Valvoline, then when it is WELL broken-in..I change to Castrol... They never seem to break in with Castrol oil..!! If you really want it to LAST, try this...!!! I have never heard of the "Break-in lube", except for the Moly Lube that comes with new performance cams..!! Be sure to place the ring end-gaps staggered approximately at the wrist pin ends...!! Have the top end-gap placed farthest from the spark plug hole...!! Have a GOOD Valve job done...and it is Good practice to take the time to POLISH all the valves, before they are cut for the valve job...removeing all sharp edges..they will not burn nearly as easily... I put the valve stem in a drill press, and use emery cloth to smooth them out, then Crocus Cloth to finish the polishing... I have my own valve grinder, and make a couple cuts on the stem-side of the valve face, to round that side of the valve before I polish them.. That improves breathing a lot...!! Have fun..!!! Ron..
Plant Doctor
11-28-2004 12:17:43
 Re: General engine rebuild question in reply to BushogPapa, 11-28-2004 09:13:18
Thanks for the info Ron. The best news I have heard so far is that I am not the only one that has never heard of this "Dry Break in Lube." It just seems to me that if this STUFF breaks in the rings it has to put a little wear on the bearing also??
Lee B
11-29-2004 03:30:26
 Re: General engine rebuild question in reply to Plant Doctor, 11-28-2004 12:17:43
Uh-Oh, looks like we can"t sell this guy any gimick but what he goes and applies common sense to it. Good job, Plant Doctor keep it up.
Chris is about the only one in this thread other than you with his head on straight. You don"t need special anything of ANY kind to break in rings as (a little known factoid) you are always constantly tearing up and rebuilding the "glaze" that allows engines to work in the first place. This is the same process as "breaking in the rings" only it goes on for the life of the engine. It"s not something that comes in a can either, the glaze is formed from the oil and all oils form it. Any deviation from the above and you really believe in magic no matter what else you say you believe in. Snake oil comes to mind all too often in this arena.
If it gives you a warm fuzzy feeling then do what you want, just don"t quit your day job and expect to sell snake oil to me for a living - you"ll starve. A decent cross-hatch pattern and any decent oil and you are off and running with the best of them, nothing else has ever been required. Past this point and it"s all smoke and mirrors, I wouldn"t pay for it myself.
Chrisfromsolitude
11-28-2004 06:42:48
I haven't ever used one either. I usually wash the cylinder walls down with dishsoap and water and then give them a good coat of motor oil. Just my 2 cents. Have heard that solvents and things of that nature won't get the honing dirt off good enough.
