Clooney- OT JD 2640
Dieselrider
02-10-2004 05:23:12
I know this isn't about an antique tractor but I could use some advice. I don't know if you can help with one this new or not but, here goes. I have a 79, 2640 with the hi-lo option and the park position on the left hand shift lever. The clutch control valve (looks like part of the tranny cover) where the shift levers go through into the tranny has a groove at the top that a retaining ring holds the shift lever into place. That groove is worn bad on the one side from the pressure it gets as the tranny is put in and out of park. This allows the ring to pop out of place and then the shifter to come loose. It can be operated this way but, I would like to fix it and not have to worry about it. I can probably have it tig welded and then re machine the groove or manufacture a steel cap and modify the aluminum to accept it but, I was wondering if you have had any experience with any of these, and might know the best route to go? I'll be calling today to price the part and check availability of the part but, I am thinking it is going to be steep if it can be had. Thank in advance for any help you can offer and I am sorry this is so long. I hope you get a picture of what I am talking about.
david val
02-10-2004 15:31:59
 Re: Clooney- OT JD 2640 in reply to Dieselrider, 02-10-2004 05:23:12
check the bottom side of the lever ball seat, they tend to wear so you get a sharp edge in the bottom. if that's ok, i don't see why the top of the snap ring seat can not ne machined and a steel ring bolted to the cover.
there should be a special washer under the snap ring, if it's missing, it can be the source of the problem.
david
Clooney
02-10-2004 13:33:04
Dieselrider, I'm afraid I have no experience with the problem you are facing.. I do so very little with the new generation tractors & what little I do I usually have to address things as I go..
~I can make a couple of suggestions though.
~The first is to give your post a little time here as maybe someone with 2640 experience will be able to help you..
~The second is to have a local dealer or welding shop either look at it or talk with them as there might be a simple weld up & machine that will get you going.
~In other situations like you have I have had some luck with using two thinner snap rings in the groove as sometimes that will be enough to hold the pressure.. The other thing that might work [if you have enough room & metal] is to drill a couple of small holes just above the snap ring on the worn side, then tap those holes for 6/32 set screws,, if you can get a couple of set screws above that snap ring it might stay put..
[email protected]
