JD 2130 power steering 4WD
Thomas
02-10-2004 04:19:31
I just bought an 1978 JD 2130 with hydraulic 4WD. The steering is really bad, its hard to stay on the road when going fast. It has been running for 5000 hours. I can turn the steering wheel about 1/4 of a turn or more without any reaction on the wheels. What could be the cause? There is allso some problem with the 4WD, its not working properly. The previous owner said it might be a leakage in a pipe somewere under the "cabbin". The lifting device in the back works fine. Sorry my bad english, hope you know what I mean I'm from Sweden.
Allso, I have some dificulties finding a shop manual for this one. Is there some other model number that i should look for (like perhaps the 2630?). I really would like to get the 4WD option included in the manual if possible.
All advices much appreciated!
Thanks all..
Brokenwrench
02-10-2004 04:44:28
 Re: JD 2130 power steering 4WD in reply to Thomas, 02-10-2004 04:19:31
The steering usually gets loose either in the tie rod ends or the cross shaft under the steering column. If you can see it (with the cab)there is a 3" diameter tin plug on the left side of the trans case below the seering column. Remove the plug and turn the steering wheel and see if the shaft is loose inside the steering arm,or if the shaft moves back and forth. If it is loose,tighten the bolt if possible,if not the shaft or arm will have to be replaced. If it moves back and forth, the bushing will have to be replaced. The 4wd is electrically controlled by a switch in the cab to a solenoid on the front of the transmission near the drive shaft.Check to see if you have 12 volts at the solenoid with the switch in 4wd position. Usually when the electics fail, the tractor stays in 4wd all the time. If the 4wd is slipping,or not functioning at all,the clutch pack may be worn out, have leaking seal rings or you have damage inside the front differential which is fairly common on those front ends.
david val
02-10-2004 16:02:17
 Re: Re: JD 2130 power steering 4WD in reply to Brokenwrench, 02-10-2004 04:44:28
to much play in the steering system is usually due to bad bearings in the bellcrank (the part that transfers the drag link longtitudal movement to the tie rods sideways movement). it should only rotate around its axis. if it wobbles, your bearings are bad. another source of play is, as mentioned, the splines between thw steering arm and the steering sector. remove the cover and try to tighten the bolt. if tight, operate the stering repeatedly from left to right and back and look for movement between parts through the opening. all parts deen (arm bolt and washer)should move as a unit.
the hydrostatic fwd is operated by a sophisticated electric system with special switches on the shift levers, clutch pedal etc, that operate electrohydraulic valves in the front axle area. a proper tm and knowledge of the system is reqired for repairs.
if the system is operational it works like this (as far as i remember): engaging the swich in low torque position (thinner circle(?) on the swich), make the left and right wheel motors work in series, thus obtaining the torque of one motor, a 'differential lock' action and higher speed. switches on the shift levers alow fwd operation in higher gears.
in high torque swich position, both motors work in parallel thus the torque is doubled, the speed is low and the switches on the shift levers limit fwd operation to lower gears only.
i think there was a separate om for the hfwd (not sure though).
david
Thomas
02-10-2004 08:12:06
Ok thanks, the switch for the 4WD is allways off since I been told something is broken. I will try put it on and see what will happen.
Thanks again!
charles
02-11-2004 00:47:27
 Re: Re: Re: JD 2130 power steering 4WD in reply to Thomas, 02-10-2004 08:12:06
The technical manual gives a very detailed fault finding sequence for the hydro fwd as david says there are a number of electro hydraulic switches to give you the various options and also switches in the clutch /gearlever to coordinate the operation . the only way is with a circuit tester and the manual , ,I have found the local Deere workshop amazingly helpful ,next day delivery of parts for 25 year old tractors and advise over the phone
