Battery corrosion
Dean Barker
11-27-2004 16:27:40
I have two pieces of John Deere equipment that have batteries, a 9400 combine (1989) and a 4320 tractor (1972). The battery terminals and clamps corrode terribly. Other brands I have don't do this nearly as bad. What is the difference and what is the best thing to use. I've tried oil,and grease. This fall I bought some "Whip" to put on the terminals. Any suggestions would be appreciated.
Dean Barker
11-28-2004 19:29:01
 Re: Battery corrosion in reply to Dean Barker, 11-27-2004 16:27:40
Thank you, everyone for the suggestions.
gasket sealer
11-28-2004 02:22:15
 spray your clean battery posts with copper coat! in reply to Dean Barker, 11-27-2004 16:27:40
Drown the connections with this gasket sealer.
Jason Z in MO
11-27-2004 19:26:44
This isn't specific to John Deere equipment...
I have seen battery terminals over torqued causing the posts to become loose in the case.
Jason
John T
11-27-2004 16:58:14
Dean, the best luck Ive had is when I use BOTH those felt washers PLUS the red anti corrosive battery terminal spray. If the charging system is overcharging that causes excess outgassing which tends to corrode. Ive seen vaseline petroleum jelly and grease etc which reduces corrosion since oxygen is kept off the terminals, but I fear it can melt and soak down in between the post and terminal which isnt a good thing.
Start with the ends n terminals n posts all clean n dry n wire brushed then the use of the felt washers and anti corrosive spray ought to do the trick, hopefully. Still, an overcharging condition can wreak havoc caused by the presence of acidic vapors.
John T
