G flywheel endplay
Daniel Chestnut
11-27-2004 16:14:46
I finally got my G crankshaft and flywheel installed. Now my problem is getting the flywheel endplay adjusted. I can get the flywheel set where I want. As I tighten the nuts, the flywheel wants start back off the crankshaft. What can I do to keep this from happening as I tighten the nuts?
Garland
11-28-2004 16:56:53
 Re: G flywheel endplay in reply to Daniel Chestnut, 11-27-2004 16:14:46
Daniel sounds like you are not getting crankshaft pushed all the way over to flywheel side. I put a chain around rear axle across end of crankshaft and tie off on frame then put a boomer on chain and tighten enough to hold crank from sliding over when you install flywheel. Mic a piece of duck tape should mic at about 6ths. and thats the clearance you need,so remove the cover that hold the thrust washer in place then remove thrust washer,take duct tape on face of thrust washer take a ball peen hammer and cut away the excess leaving the tape on the face reassemble install flywheel and seat up against duct tape on thrust washerand tight bolts . P.S. I have seen the inside splines on flywheel bradded where someone beat on it with a hammer,this will keep flywheel from going into correct position so take a look at this .Gman
2510 Bill
11-27-2004 20:35:03
Daniel,
I have a G also and went thru this a few a few years myself. First you really need a special tool for those flywheel nuts. I made one by cutting a 3/4 drive extension in half and welding in about a 3 inch offset. Then I used a couple of long timbers and blocks -one from the left forward against the flywheel, and one on the right against the belt pully and made a big clamp of sorts using a chain and binder. There probably is an easier way but it worked for me. you sure want to get most of the end play out or you will fight leaks and ruin the seals on both ends. good luck
