420w power steering pump need help
Henry James
11-27-2004 15:51:33
I have a 420w 58 model ser#128297 slant steering, it has a bad power steering pump and it's missing the belt pulley. I'm looking for a good pump with pulley or a place to have mine rebuilt. Sure could use any information.
If anyone has one for sell you can call me at 304-749-8503 or post your # and I'll give you a call.
Thanks Henry!
RAY H
11-29-2004 13:31:29
 Re: 420w power steering pump need help in reply to Henry James, 11-27-2004 15:51:33
HENRY, I'M A LITTLE HARD TO CATCH, SO YOU CAN CALL AROUND 5 PM CENTRAL TIME, OR E-MAIL ME AT TOYHARTZ @AOL.COM . YOU WILL NEED TO HAVE A PULLY MODIFIED TO FIT THIS NEW PUMP. IF YOU STILL HAVE YOUR OLD ONE AND THE CENTER IS WORE OUT, THAT'S OK. A NEW HUB HAS TO BE MACHINED ANYWAY. 417-751-3878
RAY H
11-28-2004 14:29:27
I HAVE THE INFORMATION YOU NEED TO UPGRADE YOUR PUMP AND SYSTEM. FOR THE MOST PART THERE ARE NO REBUILT PUMPS OUT THERE, THE SAGINAW PUMPS WERE NOT MADE TO REBUILD. THE DEALERS WILL NOT HAVE ANY NEW ONES, SO YOU ARE GOING TO HAVE TO UP GRADE.
Henry James
11-28-2004 17:11:17
 Re: 420w power steering pump need help in reply to RAY H, 11-28-2004 14:29:27
Hello Ray H, I sure would appreiate any info you can give me on the update for the power steering for my 420w. Can I call you?
Best Regards Henry James!
JDG
11-27-2004 19:17:20
Henry If you are near H"burg Va, check with Bowman Bros in Mt Jackson Va they may help!
Chrisfromsolitude
11-27-2004 18:19:46
I have an extra power steering pump from a black dash slant steer 420W. I would be interested in selling it. I haven't got a clue if it works or not. I can put some fluid in it and see what happens tomorrow. Also I don't think it has a pully on it either. My number is (812)781-0057. I also have a few other 420 parts I want to get rid of because I don't have the tractor anymore. Thanks and have a nice day.
Henry J
11-27-2004 16:47:06
Henry
I am kinda in the same boat, I got all the pieces but the ps don't work worth a flip.
Anyway, I just had a thought. There is a possibility that your JD Dealer could come up with a rebuild, I don't know.
But when I had to rebuild my water pump, the JD dealer could have ordered a rebuilt one for me. Maybe same on the ps. Maybe worth a try.
Ray: If you check this post again, do you know which pump would interchange from the automotive line? I got the one with the small neck and cap.
Ray
11-27-2004 16:34:16
You can use an automotive type pump.
Ray
11-27-2004 17:53:50
 Re: 420w power steering pump need help in reply to Ray, 11-27-2004 16:34:16
I put one on a few years ago from a 70'S model
buick,had to do some fabrication work,but the bracket was heavy enough to do what I needed.
I don't think the original pumps had enough
pressure when they were new.
Henry James
11-27-2004 18:10:24
 Re: 420w power steering pump need help in reply to Ray, 11-27-2004 17:53:50
I checked with a dealer in Harrisonburg, Va and he said he may be albe to get some parts if I knew what I needed but could not get me the pulley. I'm hoping someone on here will have good one for sell.
Henry!
