Cyclone B ???
Loren-MN
11-26-2004 19:45:08
There is a John Deere Cyclone B for sale in the photo ads. What is a Cyclone B and how is it different from any other B?
Stan - Florida
11-27-2004 04:22:53
 Re: Cyclone B ??? in reply to Loren-MN, 11-26-2004 19:45:08
Loren,
I'll send you a scan of an ad from '47 or thereabouts. We had our '43 B converted to this new and improved engine in '47 and moved up from a 1-16" plow to a 2-12" plow. Also had the steel wheels cut off and put on rubber and added 5th and 6th gears. All in all, it was like a new tractor.
If anyone else is interested, I'll post the same scan in the Tractor Photos section. I'll call it Cyclone Engine.
Stan
CLW
11-26-2004 20:29:05
Cyclone B was a name given to the late styled B (47-52) by who only knows. It had to do with the eyebrow just over the intake valve. It would direct the incoming fuel downward in a swirling motion. Made for better engine performance and more power. It would apply only to the 47-52 year model.
CLW
CMB
11-27-2004 05:26:02
 Re: Cyclone B ??? in reply to CLW, 11-26-2004 20:29:05
Actually I believe the head with the "eybrows" was introduced at serial #99000, my dad bought a new B in October of "41 (125xxx), & it came from the factory with this style head. However I don"t recall the term "cyclone" being used until the "pressed frame" Bs were introduced in "47.
CMB
11-27-2004 10:16:04
 Re: Cyclone B ??? in reply to CMB, 11-27-2004 05:26:02
Just checked the parts manual, & I was wrong on the serial # that changed to the new style head-it was 96000 not 99000. According to this, they used this same head till the end of B production.
Stan - Florida
11-27-2004 11:26:18
 Re: Cyclone B ??? in reply to CMB, 11-27-2004 10:16:04
CMB,
Since the bore was increased to 4-11/16" from 4-1/2" at S/N 201000, would the same heads have been used?
Stan
CMB
11-27-2004 12:16:46
 Re: Cyclone B ??? in reply to Stan - Florida, 11-27-2004 11:26:18
In short-I don't know, however the part# stayed the same from #99000 on (AB4204R)till the end. However, as someone else stated, there were at least three different casting #s (B1784R, B2501R,& B2871R), but apparently they were all interchangable. With the larger bore on the '47-'52 engines it would seem that the recess in the head should be larger. Maybe that's what the later casting #s provided for. (This is ALL speculation on my part.) Hopefully someone with more knowledge can shed some light in this.
Mike M
11-27-2004 13:45:34
 Re: Cyclone B ??? in reply to CMB, 11-27-2004 12:16:46
I have parted out lots of B's from 1941 to 1952 in the past and all of the heads I have seen will interchange. Only differance I ran into was on a later casting number you had to use a different washer that went over the center stud to feed oil pressure up to rocker arms,and some have push rod tubes and the later one don't.Combustion chambers and valves all the same.
Mike M
11-27-2004 06:51:52
I agree as the parts book lists several casting numbers for heads but they all fit from like 1941 up to 1952 and look the same.
CLW
11-27-2004 11:45:21
 Re: Cyclone B ??? in reply to Mike M, 11-27-2004 06:51:52
I have no dought all of you are correct in what you are saying. The information I had came from 1998 May-June TWO CYLINDER page 10. It says "The engines were revised from previous models, with a key feature being an "eyebrow" just over the intake valve." It also says " To convert an all-fuel tractor to gasoline, all the owner had to purchase was a gasoline piston set and a cold manifold. The carburetor difference was not significant enough to warrant being changed."
CLW
