Yarber, lets start with it being a fuel/carb problem, but if its ignition related we will do more later. Although youre right, the only sure way to adjust the carb is under a good load, I can get you in the ballpark at least. Start with the carb adjusted with the idle needle closed down then open back out about 2 turns and the load needle back out about 1 turn and see how she does. If that dont do the trick, set her at wide open throttle and keep opening the load needle (richen mixture) till she starts to load up over rich and throw black smoke out the stack, then screw it back in leaner just till she stops smokin. Does choking some help her when she starts to cut out???? If so, shes lean, maybe a fuel restriction or a carb problem. Even if the carb is clean and right, you still need good fuel flow to the carb. Turn the gas on and open the carb bowls lower drain cock/plug and insure a good steady stream of gas runs out about 1/16 inch in diameter a minute or two, If not, there may be a restriction in the needle n seat,,,,, ,or the carbs side inlet strainer,,,,, ,or the sediment bowl,,,,, ,,,or tnak outlet or sed bowl inlet pipes,,,,, ,,or any 3 way brass changeover valve. YOU GOTTA HAVE GOOD FLOW GETTING TO THE CARB FOR IT TO WORK OKAY UNDER LOAD. If the float level is way too low she can also exhibit the problem you described. Check the plugs and install fresh new ones if they are any at all burned or carboned up or fouled. Likewise, if the poins are burned or pitted or gray oxide coated, change and gap them. Theres more but I gotta meet a friend I will check back later. Adjust the carb,,,,,check fuel flow to carb,,,,check the plugs n points n post abck findingds and if choking helps her run better. John T
