1963 3010 loader?
Eric Harrington
11-26-2004 18:47:52
I recently purchased a 1963 JD 3010 with wfe. I am interested in purchasing a loader for it. Can anyone tell me what loader models fit this tractor? So far from the information I can find it appears that the JD 148 is the only loader model that is an option. Is the 148 the best option?
Eric Harrington
11-27-2004 20:31:18
 Re: 1963 3010 loader? in reply to Eric Harrington, 11-26-2004 18:47:52
Thanks to all of you who responded for the great information. Now for the hardest part, finding a loader.
Johnsdeere
11-27-2004 08:32:12
48,148,58,158, and 35(a little light) some 46 loaders also. These are the John Deere loaders for it. I would suggest the 48 or 148. They are easy to find at auctions and in farm papers.
Mike Aylward
11-27-2004 18:34:41
 Re: 1963 3010 loader? in reply to Johnsdeere, 11-27-2004 08:32:12
Just wanted to mention that while the 58 and 158 loaders will physically fit on a 3010 they are not recommended by Deere due to their length. I have a 158 on a 4020 and if you measure from the bucket edge to the front wheels you will find that it is very close to the wheelbase measurement. In other words, the front axle is almost in the middle of the distance from the rear axle to the bucket edge. The 3010 is shorter and this length ahead of the front axle to the bucket will be excessive (more than the tractor wheelbase) and make the tractor unstable in some instances. The loader's ability to lift more will compound this. Mike
laborintensive
11-26-2004 21:36:08
Eric,
Went through this a month or so ago. I have a WFE 3010 and looked for a 148 but didn't have much luck finding one. I ended up with a K/D loader, but for the life of me I can't remember the number, 2100 or something like that. It has quick tach on both the tractor and the implements and is build very well (I think). The guy that started building them used to design Koyker, but started his own company.
You can get many colors and I put a joystick on this one which is great. The fittings are all hydraulic fittings, the mounts are stout and we plumbed it where with two quick connects all the hydraulics are unhooked and ready to come off of the tractor with the loader. I think it was $4200 put on, which was more reasonable than the Deeres I was looking at.
If you need any more info. yell back!
Gerald J
11-26-2004 19:10:41
The 48 is another option.
Gerald J.
thurlow
11-26-2004 19:01:51
46A..... lighter duty, but a good "fit"
