buickanddeere
Bgiese
11-26-2004 17:59:29
420w missing serial tag checked on the starter situation 1 bolt versus 3 bolts and came up at odds with your sugestion, the tractor is a straight steer 5spd with live pto but has 2 bolts holding the starter on. any idea"s Thanks
Jim Nauert
11-27-2004 14:59:17
 Re: buickanddeere in reply to Bgiese, 11-26-2004 17:59:29
Acording to my 420 parts book the ser# cut off for the single bolt starter nosing is 100,000. after that they call for the two bolt nosing. the ser# info i have from the two cylinder club i belong to has the 56 420 ser# going up to 107812 so i feel that using the starter as a reference for the year of your 420 would not be a acurate way to go about it. If you were to get a parts book maybe you could find some part that will not interchange. i didn't take the time to look for it. Good luck with your serch. I also am not trying to offend or prove anyone else that is trying to help wrong you most of these guys know alot more than i do on the subject. I'm just showing you the facts that i have.
buickanddeere
11-28-2004 20:06:36
  57 production began at 100,000 on July 30th 1956. in reply to Jim Nauert, 11-27-2004 14:59:17
Jim, your numbers are out of whack. The 1957 production year for the 420 Yellow Stripe Straight Steer starts at 100,000 on July 30th 1956. I don't if your book is using but it's not accurate. So the two bolt starter was used on the 1957 and 1958 models of the 420 only. The 1956 420 used the model 40 style single bolt starter.
Henry J
11-27-2004 16:49:35
 Re: buickanddeere in reply to Jim Nauert, 11-27-2004 14:59:17
Jim
I looked in my parts book just for the hey of it today and came up with the same conclusion.
Jim Nauert
11-27-2004 17:29:13
 Re: buickanddeere in reply to Henry J, 11-27-2004 16:49:35
Henry J, My parts cd also shows that 5speed live pto from ser#100001-125000 and 125001-up. This tells me that 56 420's could be had with 5speed live pto.
buickanddeere
11-27-2004 07:35:32
The 56's used the same single pointed bolt on the right side of the tractor just like the 40's did. I've loosened that bolt off a bunch of times and shook the starter to un-jam them. The 57 and later bolted the starter on flange style like they all are today. Unless some tinkerer has mixed and matched parts in the past 49 years.( possible) The 5 speed and live pto could not be had until the yellow stripe straight steer 1957 model. Dubuques are noted for keeping the same bolt patterns. All sorts of combinations over the years can be bolted together to make tractors that are one of a kind.
Henry J
11-27-2004 06:21:53
Begiese
Just for grins, where do you put the oil in. Does it have a filler at the dip stick or do you pour it in on top?
If you pour it in at the dipstick, the block has probably been changed.
Ray
11-26-2004 18:15:22
1957 model
