JD - early styled B sn# 81291 transmission
Jason Z in MO
11-25-2004 20:39:58
Still working on the B restoration project and have a couple of questions...
1) clutch adjusting disk - Cleaning up some surface rust on the clutch disk mating face and found some cracks. One is about 1 1/2 long running the from the inside to the outside edge. It doesn"t appear to be cracked through. I can"t find it on the opposite side where the re-enforcing ring is cast into it. Are cracks common and is this casting available? (doesn"t look like Deere has any)
2) Transmission sliding over/under drive gear (Hi/Lo) - There is some play between the gear and the sliding shaft. It doesn"t seem excessive but by running my finger along the length of the sliding shaft I can feel wear. I know this is hard to answer but how do you know when there is too much play?
On the shifters I did find the yokes (or shifter forks) that rivet to the shifter slides to be loose. The yoke for the Hi/Lo gear was REALLY loose. I peaned the rivets tight again.
Thanks for any suggestions,
Jason
