720d standard wheel problem
Tracy Redd
10-10-2003 23:08:00
I bought this 720 last summer. A man who the own this before me, has started clean up the 720 get ready for painting but he pass away. The rear wheel was off and somebody put it back on and tighten up. So I bought it then finish up the rest of it. I have a big problem, I cannot get the rear wheel loose. I have spent hour and half trying get it loose but no luck. There were one jack bolt that are not catch up the thread on wedge. I tried push jack bolt in to catch the thread but it pop back out. the wheel it tighten on edge of the axle.I have done this before with my other John Deere but this one is the worst one.
Is that the only way is heat it up and get sledgehammer, hit it get the wedge out. This tractor is not running and It has two wheel weight in inside the wheel( not outside). If you know the best way to do it, give me your answers
Thanks
Tracy
Roger
10-11-2003 06:25:00
 Re: 720d standard wheel problem in reply to Tracy Redd, 10-10-2003 23:08:00
Dad has a 4440 that we move the wheel out every fall for plowing, the first time we did it, I didn't think it was ever going to come loose, we had the jackscrews as tight as we could & I had been hitting right on the bolt heads to try to pop the wedge loose, NOTHING, I looked at Dad & said "Do I dare hit it has hard as I can?" he said do it, so I hit the bolts 2-3 more times & finally BANG, it came loose. Ever since then we put the silvery Never Seez goop on the wedge & it dont take much anymore to pop the wedge loose. I hated to hit the bolts that hard but I don't like using heat on cast wheel centers either, that's why I've never moved the wheels on my Case 1370, I know it would take heat on them!
