4620 water pump
as
11-24-2004 07:47:54
How big of a job is it to replace or rebuild?
Does the radiator need to come out?
Mine seems to be leaking around the pulley.
Thank you.
msb
11-24-2004 18:42:47
 Re: 4620 water pump in reply to as, 11-24-2004 07:47:54
Remove the radiator and if the engine has been running a bit warm,it is a good time to have it cleaned especially if it has been quite a while since it was last removed. Look inside the top hose hole for evidence of lime build up.And while you have the radiator off it is a very good time to relplace the fan belts,radiator hoses and hydraulic pump drive coupler bushings.None of which is very expensive and could save you considerable time when you are using the tractor heavily next spring.
G/MAN
11-24-2004 13:39:02
Removing the radiator isn't strictly necessary, but will probably make the job easier overall, particularly removing the old gasket from the front of the engine. I'd also recommend replacing the thermostats while the coolant is drained, and replace the coolant if it's more than a couple years old. Removing the radiator would give you a chance to give it a good cleaning as well. The pump should be rebuildable providing it isn't completely shot and hasn't worn into the housings.
JDBert
11-24-2004 11:20:25
When I did mine I dont remember taking the radiator out, (fairly big job). I think I just removed the fan and then took the pump out. I was able to rebuild mine, but we caught it real early before it started to leak.
2 Cylinder
11-24-2004 08:53:01
I replaced one last year on a 4520, if I remember correctly you will have to pull the radiator. You'll have alot more room to work, and not risk puncturing the radiator when you remove the fan. Others maybe able to shed more light on the topic, of, if there is a way of doing it with the radiator in.
