14T Pick Up Tines
EricB
11-24-2004 06:23:39
I need to replace several pick up tines on my 14T baler. I have been trying to removed the flat guides that cover the pickup rake. Unfortunately the screws have very soft heads and are seized. I am afraid of twisting the screw heads to an unusable shape. Do I need to remove these flat cover bars to replace the tines? What is the best way to remove the screws? I do not have a torch, and have soaked penetrating oil into them for almost 2 months.
Any suggestions welcome.
old
11-24-2004 07:53:10
 Re: 14T Pick Up Tines in reply to EricB, 11-24-2004 06:23:39
This will only help you if you need parts, I have a 14T and a 24T that would be good for parts. I'm in Missouri if you want more info e-mail me
walter squires
11-24-2004 07:34:43
Heat the bolt head red hot let cool completly you may have to do this a couple times, Put some water with a few drops of soap in a spray bottle, wet them good, I have a 99% success rate doing this. I think snake oil is a joke I have much better luck with water on rust.
