420w john deere missing serial tag
Bgiese
11-23-2004 17:52:01
my father recently accuired a 420w straight steer with a loader on it no serial tag, also no number on the block below the generator only number on block is a casting number m3037t on the carb side any ideas on how to determine a year of production
it has a single touchomatic, foot throttle,
Maark
11-24-2004 06:44:14
 Re: 420w john deere missing serial tag in reply to Bgiese, 11-23-2004 17:52:01
on the right side of the block, towards the front, just below the hydraulic pump is a flat raised boss type area. There is a ser.# stamped there. Read that number and contact the area service manager at your local dealership or contact Two-Cylinder Club. They should be able to get the tractor ser.# from that, and your Area service manager can get you a duplicate ser.# plate.
Henry J
11-24-2004 05:51:58
Bgeise
Here some things that supposedly came out in 57 that were changes from the 56 mode.
5 speed trans was an option.
The gate type shifter showed up for the 5 speed.
continuois pto was an option
The 57 was the first with the two tone paint
They also changed the grill medallions from 56 to 57 but I can't describe in detail the difference.
buickanddeere
11-23-2004 19:28:29
If one bolt holds the starter on it's a 1956. Three bolts and straight steer it's a 1957.
Ray
11-25-2004 09:45:29
 Re: 420w john deere missing serial tag in reply to buickanddeere, 11-23-2004 19:28:29
My 420'S and 430 have 2 starter bolts.
Jim Nauert
11-24-2004 01:35:58
My 420w ser#106096 has 3 bolts holding the starter on and is a 1956. The person i bought it from said it was a 57 but the ser# info i have says it's a 1956.
buickanddeere
11-24-2004 05:59:12
 Re: 420w john deere missing serial tag in reply to Jim Nauert, 11-24-2004 01:35:58
Odds are in that in the past 49 years. Someone has bolted on salvage yard parts and she now has a mixed heritage. 56's didn't leave the factory with three bolt starters, five speeds, a yellow stripe or live pto. Yet all kinds are out there.
Ray
11-23-2004 18:28:12
If it"s a straight steer it would be a 1956 or
1957 model,the 1958 models were slant steer.
