720 clutch problem update
Billy Ben
11-23-2004 17:19:37
Any ideas on how to remove the clutch driver. There are no holes drilled in it to use a puller or jacking bolts as shown in the service manual AS you can see I am new to these John Deeres.
buckdye al
11-24-2004 10:10:51
 Re: 720 clutch problem update in reply to Billy Ben, 11-23-2004 17:19:37
Gotta agree with the others, should be a pair of tapped holes in the driver. They should be through the back flange of it, NOT in or near the center splined hub. They're only visible after ALL of the outboard plates & facings have been removed. Just going from memory here at the computer but you should have removed the outer plate by removing the castle nuts. It would have a dry disc in it. You should remove a floating steel ring loosely splined and floating on the hub of the clutch driver then a double faced clutch disc etc. Sounds to me like maybe you need to dig a bit more until you get to the back flange of the clutch driver. If you're already there then I'd agree whole heartedly with Frank. Grab the drill. I defer to Frank on where but as I recall the holes are between the outer splined surface of the driver's hub towards the crank roughly a half to 3/4ths of an inch from where the dry disc rides on the flange.
720Deere
11-24-2004 05:27:02
I've been into a few of those clutches and have never seen a 720 driver that didn't have the holes. That driver doesn't move easily at all. I usually have about all I can put on the bolts with a long handled 1/2" drive ratchet before she pops! I don't know of any puller that would have the guts to pull one of those.
F-I-T
11-24-2004 05:25:52
BB:
As has been said, there SHOULD be two 1/2" threaded holes opposaite each other to accecpt pusher bolts. If your driver does not have them, you can try a large bearing splitter on the gear to extract the driver.
What I would choose to try would be to drill two holes and tap them, then install pushing bolts. Itr can hurt. THe driver is pretty soft stuff and should drill and tap easily. Just take your time.
Frank-in-Tallahassee
JD 70D // JD 855 // Case VAC // �48 IHC Cub // �41 JD �H�
[email protected]
F-I-T
11-24-2004 05:36:01
 Re: 720 clutch problem update in reply to F-I-T, 11-24-2004 05:25:52
I meant to say..."it can't hurt to try"....
greenmech
11-23-2004 20:47:37
Should then come off by screwing in the bolts ,as the pushers. Good luck.
greenmech
11-23-2004 18:53:46
After you take the outer plate off and get to the driver there should be two tapped holes to screw in 1/2 in. bolts. Maybe the holes are full of gunk.
Billy Ben
11-23-2004 20:09:25
 Re: 720 clutch problem update in reply to greenmech, 11-23-2004 18:53:46
There are 1/2 holes in the driver
Billy Ben
11-24-2004 01:57:47
 Re: 720 clutch problem update in reply to Billy Ben, 11-23-2004 20:09:25
I should have said that there are no 1/2 holes in the driver
Lee B
11-24-2004 04:15:43
 Re: 720 clutch problem update in reply to Billy Ben, 11-24-2004 01:57:47
Don"t know if it applies or not but recently on my A I was confused by said picture showing bolts and a guy happily twisting away on them. Text said 1/2" bolts and it finally all came together after some ten minutes of looking at the picture and what I had to work with. I used 5/8" bolts and square nuts on the back side of the square slots and happily twisted on both just like in the picture. I also had the bolt and washer that holds the driver on the crank installed with some amount of slack in case the driver decided to sprout wings and fly off there. It didn"t, my fears of decapitating myself were totally unfounded. Required square nuts were not mentioned or shown anywhere, go figure. Wrong size of bolt to use also not much help.
greenmech
11-24-2004 04:12:23
Got all the discs out before the driver? I think there may be some thing in front of the driver yet.
