4010 Rod Bearings
Hoosier JD
11-23-2004 16:08:20
I finally determined the knock in my 4010 gas was not the hydraulic pump or pump coulpling as I unhooked it all and ran the motor....knock was still there. I then took the pan off and took the rod bearings out... they varied in thickness as much as .004 to .006. Any suggestions or advice when I put the new bearings in? I put calipers on the crank and they all seemed to read within standard spec. I then ordered new standard bearings and new rod bolts from JD and they will be in tomorrow. I am anxious to get it back together, but want to do it right as much as is possible. Thanks, Mike
F-I-T
11-24-2004 18:51:19
 Re: 4010 Rod Bearings in reply to Hoosier JD, 11-23-2004 16:08:20
My 2 cents is that if you measured the crankshaft journals (throws) with a caliper, you are asking for inaccurate measurements. Get a quality micrometer, preferably carbide faced, preferably with a .0001" vernier on the barrel. You will almost always neasure fatter with a caliper than with a mike.
Frank
JGC
11-24-2004 18:20:19
Make sure each throw and journal are round and within spec.
Plastigage each new bearing regardless of what you measured with the micrometer to make sure each one is within spec. Assemble with assy grease, and make sure you get normal oil pressure while cranking before running the rebuilt engine.
Hoosier JD
11-24-2004 18:32:46
 Re: 4010 Rod Bearings in reply to JGC, 11-24-2004 18:20:19
With std. bearings and stock crank, what should the plastigage read? You spoke of "throws"... to what are you referring? It's been so long since I have done any internal work, I don't know where to buy plastigage..... parts house? I really appreciate all the help on this project! I'm probably not going to work on it until this Friday or Saturday. I've left my email open for any more suggestions. Thanks, Mike
JGC
11-24-2004 19:23:34
 Re: 4010 Rod Bearings in reply to Hoosier JD, 11-24-2004 18:32:46
The crank rotates on the "mains" - main bearings and the connecting rods ride on the "throws" or journal bearings.
I don't have the clearances for that engine so someone else will have to provide them, or call Deere.
Plastigauge comes in several measurement ranges. I would buy a couple of packages of a couple of ranges in case you have a tight or loose bearing to measure. Seems to me the range is .001" to about .004" and .003" to .008 or so.
Every good NAPA or other auto parts place or engine rebuilder should have it. Cheap insurance to check each bearing just in case one was switched in the box at the jobber, etc, etc.
one brand ->Link
ok>Link - two brands ->Link
Good>Link Luck,
JC
matthies
11-23-2004 20:26:59
While you're down there and installing the bearings/bolts look closely at the piston skirts to see any hot spots/vertical grooves to see if you might have a scored piston. chris ps Look while the piston is at the lowest point.
Earl S.
11-23-2004 20:13:57
Std crankshaft diameter on rod journals is 2.998-2.999 I think the diameter spec he gave you was the reject size. Earl In Illinois
Bob
11-23-2004 19:04:26
Did you look closely at the old inserts? They could POSSIBLY be .001", .002", or .003" undersize, or may be labelled "STD".
If the originals were standard, and you install new standard bearings, verify the oil clearance with Plastigage against factory specs.
Did you check the crank journal diameter at several points, as the crank does wear "out of round"?
Good luck, it is seldom that an engine with a noticeable knock can be successfully (for the long term) repaired just by the installation of new bearing inserts.
Hoosier JD
11-23-2004 19:12:50
 Re: 4010 Rod Bearings in reply to Bob, 11-23-2004 19:04:26
The old bearings were stamped std. JD had me measure the journals, which were supposed to be 2.985 to 2.995 and they measured 2.993 to 2.995 just about anywhere I checked them. The problem is, this is the first time I"ve ever tried to do something like this without pulling the motor and having it on an engine stand in front of me (usually small block chevys). Thanks, Mike
Bob
11-23-2004 19:25:15
 Re: 4010 Rod Bearings in reply to Hoosier JD, 11-23-2004 19:12:50
If the crank does not have any major grooves or damage, and the clearance with the new bearings checks out with Platigage, you should be OK!
While each rod is undone from the crank, wiggle it around a bit (being carefull not to nick the crank) to check out each wrist pin bushing for unusual looseness, which can cause a knock, also.
