DLTX 26 vs DLTX 46 carburetor
J.P.
11-23-2004 15:08:32
What is the functional difference between the two different carbs.? We have both available for our H and we are wondering with which to spend the time and effort rebuilding. Any help would be appreciated.
Donny-B
11-23-2004 15:35:29
 Re: DLTX 26 vs DLTX 46 carburetor in reply to J.P., 11-23-2004 15:08:32
The model 26 was used on early H's (39-40 I think) that were hand crank only. The model 46 was standard equipment for the remaining years of production. The only difference I know of is that the 26 had a hand choke lever and the 46 choke was operated by a rod on the dash. Both carbs will work on any H and are worth rebuilding. Check on Ebay as to what they sell for.
dan_41jdh
11-23-2004 15:35:20
J.P., the only difference between the DLTX 26 and 46 is the choke handle and choke butterfly. The DLTX 26 is the correct carburetor for s/n 26999 and earlier. The handle on that model pushed down to choke, and did not have a provision for a choke rod that led back to the operator"s platform. S/N 27000 and later (when electric starting became available as an option) used the DLTX 46. The DLTX 46 choke handle pulled up to choke, and was outfitted with holes to accept the choke rod that was furnished if the tractor was equipped with the optional electric starting. Anyway, the internal parts are interchangeable between models (except for the choke handle and butterfly, which must stay with the proper carb). So, if you have an electric start model, you really should use the DLTX 46, especially if you want to operate your choke from the operator"s seat. If your tractor is a hand start, the "correct" carburetor depends on your serial number: before 27000 = DLTX 26.
J.P.
11-23-2004 17:05:37
 Re: DLTX 26 vs DLTX 46 carburetor in reply to dan_41jdh, 11-23-2004 15:35:20
Thanks - exactly what we needed to know
