1940 L Transmission
John F in MD
02-09-2004 18:41:09
How hard is it to replace the input shaft bearing in a 1940 L transmission? Does the entire trans need to be disassembled?
The trans works fine, other than the noisy bearing.
Al
02-10-2004 17:56:35
 Re: 1940 L Transmission in reply to John F in MD, 02-09-2004 18:41:09
It is pretty easy. Take the side cover/shift assembly off by removing the four bolts. The upper shaft comes out the front with the removal of four more bolts. If it is the input bearing you will have to pull spider off the front of the shaft.
