JD A Year Model? (CLW, Loren, Larry)
BB
02-09-2004 18:40:39
I now have more info so yall experts can help me find out my year model(serial tag gone) It is an A and it has the battery under the seat and a pressed steel frame. It has a single stick to change gears and with one slot per gear. It has the square axle housing and the choke lever is mounted on the left lightbar with a bracket. If more is needed to narrow it on down please let me know.
Thanks,
Butch
Loren - Minnesota
02-09-2004 20:58:21
 Re: JD A Year Model? (CLW, Loren, Larry) in reply to BB, 02-09-2004 18:40:39
Butch -- I have to agree with the others, late model 1950, based on the information you have. Loren
CLW
02-09-2004 20:41:22
Butch, Mr Thinker is correct. In your first post you said the guy you got it from said it is a 1950 model. Unless you have some reason to think otherwise I would think it is going to be late 50 model. About the only other change I can think of off hand is the very late 52 had a water pump.
CLW
Mr Tinker
02-09-2004 21:25:46
 Re: Re: JD A Year Model? (CLW, Loren, Larry) in reply to CLW, 02-09-2004 20:41:22
CLW
THANKS! Wish I was a THINKER, but I just TINKER. LOL
CLW
02-09-2004 23:22:41
 Re: Re: Re: JD A Year Model? (CLW, Loren, Larry) in reply to Mr Tinker, 02-09-2004 21:25:46
Sorry about putting the H in there but you were right on with the information.( I had seen that name somewhere before. Ha )
CLW
Larry806
02-09-2004 20:29:41
I'll take a WAG and say it's a 51
Mr Tinker
02-09-2004 19:32:45
I am no expert but IF the choke rod support is original, it started at serial #662728; so that tells us it is 1950 or later. Some of the main case castings had a date cast into them, it should end in 50, 51 or 52. This will not tell you when the tractor was MADE, but will tell you when that part was poured,it may not have been assembled till several months later. Hope this has been of some help.
