4320, 4430 or 4240 ?
HA in Oh
11-23-2004 08:38:35
Looking for a 110 to 130 hp open station tractor to help take some load off my 4010. I need both 540 and 1000 pto thats why I'm looking at these models. A 4440 is out of my price range. Like to stay in the 10 to 15,000 range. I've heard that 4320 and 4430 like their feul, I don't like the sound of that. Witch of these tractors are the most economical and reliable? What would you recomend? Thanks. HA
Doug in IL
11-24-2004 06:52:58
 Re: 4320, 4430 or 4240 ? in reply to HA in Oh, 11-23-2004 08:38:35
I like the 4320. No plastic parts on those! Mine has been a great tractor. I don't think there would be enough fuel economy differences in the tractors you mentioned to be noticeable.
jsp
11-24-2004 07:50:13
 Re: 4320, 4430 or 4240 ? in reply to Doug in IL, 11-24-2004 06:52:58
I agree. I've run all three and like the 4320 the best, although I am a bit partial to the New Generation style tractors. Based on what you are looking for (open station, horsepower and price) I would say the 4320 may be your best bet. Don't underestimate this tractor on horsepower, it won't disappoint.
There has been a nice one posted for sale for quite a while (http://www.tractorshed.com/cgi-bin/photoads/classifieds.cgi?search_and_display_db_button=on&db_id=85339&query=retrieval). It looks in nice shape and may be worth the look.
RickB
11-23-2004 16:12:11
I have owned all three, and the 4240 would burn 5 gallon an hour parked in the shed; over 7 on a forage harvester. I never heard of a 4240's fuel economy being bragged up. Had some other comments, but decided to look up the HP/hrs per gallon specs from the Nebraska tests. 4430 Quadrange 15.56. 4320 Synchro Range 14.65 4240 Quad 14.33. 4240 Power Shift 14.20. Higher value is better. Apparently the 4430 Power Shift wasn't tested. Wouldn't have thought the 4430 was the best of the lot, but mine was turned up some. Your luck with any of these will be based on current condition more than other factors.
power cat
12-07-2004 17:56:54
 Re: 4320, 4430 or 4240 ? in reply to RickB, 11-23-2004 16:12:11
I had always heard the 4240 was not very fuel efficient. I am considering replacing a 4430 Hyd Front A with a 7410, chore tractor.What are the opinions on the power and wt comparisions
JDknut
11-23-2004 15:16:41
For that HP range, if you can find one, a Case 1170 or 1175 might give you the best HP for the buck. The Deeres are great but have high resale value, the Cases are less money for the size, but are just about as rugged and reliable.
G/MAN
11-23-2004 10:39:11
The respective fuel economy of each is going to come down to how each is used, and on the specific machine itself. Obviously since the 4320 and 4430 use turboed 404 engines and make more horsepower than say a 4240 with a naturally-aspirated 466, they're going to require more fuel to do so if used hard and pulled at rated RPM all day long. However, for light-duty part-load jobs, I doubt you'll see a substantial difference between a turboed 404 and the naturally-aspirated 466 in the 4240. Maybe a half-gallon or so per hour worst-case, if that. What condition the engine is in and how it's operated and maintained has the biggest effect on fuel economy. But any older 110-130 hp tractor is probably going to burn more fuel than your 4010.
Txsprigger
11-23-2004 09:21:31
The best of the lot is the 4240, but around here, you will pay as much if not more than you would for a 4440. Weekenders and part-timers like them for the fuel economy.
