Adding a pto to a 47 D
Paul.D.Canada
11-22-2004 17:24:40
I would like to add a pto unit to my D.I would like to know how difficult it is and How much internal work needs to be done? The bracket that the lever arm would attach to is not there, but is all the internal gears and stuff in there?Any help would be appreciated, thanks in advance, Paul.
2cylfarmer
11-22-2004 20:56:47
 Re: Adding a pto to a 47 D in reply to Paul.D.Canada, 11-22-2004 17:24:40
I add pto to my '36 D. The shift lever is on the rear bearing quill for the PTO shaft. So without a PTO you will not see a place to have a lever. You will need to install the shifter housing into the side of your transmission, on the left side, ahead of the axle housing, toward the top of the transmission case. It is partially behind the flywheel, so it will have to come off. The shift fork comes down throug the top of the case,into the shifter, with a rod connecting to the shift lever on the rear bearing qill & shaft which slips in from the back.
If you are lucky, I have seen a few tractors that have the shifter, but no rear shaft. Then all you would have to do is install the shaft & rear bearing quill. If your tractor has a cast iron housing bolted to the side of the case just to the rear of the flywheel toward the top of the case, you might be one of the lucky ones. If it is just a steel plate in there, you will need the shifter. The gear to drive to PTO should already be in the transmission.
hope that I have not confused you too much
