three point hitch question
Ace from Oklaho
11-22-2004 15:27:45
How many inches are the bottom arms of a three point hitch supposed to be off the ground in the bottom position for a 1946 JD Model B? Any help is appreciated.
ace oklahoma
11-23-2004 16:03:48
 Re: three point hitch question in reply to Ace from Oklahoma, 11-22-2004 15:27:45
im pulling a 14 2 bottom plow i got a aftermarket hitch and the bottom arms are 1 inch off the ground this burrys the plow and the the wheels just sit and spin how many inches should the arms be off the ground in the down position with the adjusting arms tightened all the way up 8in 10in 12in 14in ?? i have to redrill the adjusting arm holes on the bottom bar i need to know where to start 1946 b jd
JDVan
11-22-2004 18:55:13
The 1946 JD A did not come from the factory with a three point hitch so you must be trying to add an aftermarket three point hitch or an 800 series hitch to it.
How far the draft arms need to drop is quite dependant on what kind of implement you are trying to use with the hitch. Category II implements tend to have a much higher hitch point than do category I implements.
Sometimes lift link extensions are required on a category II class hitch to connect to Category I implements.
