J.D. puzzeled!
BOBBY TAYLOR
11-22-2004 10:17:36
Working on a jd 2040. It keeps breaking the gear in the hydraulic pump in transmition .Three all together .After the first the others broke around three hundred hours . He's useing a six foot bush hog . Hit a stump the last time .
WTW
11-22-2004 11:32:23
 Re: J.D. puzzeled! in reply to BOBBY TAYLOR, 11-22-2004 10:17:36
Seen this same problem on newer utility tractors, Gear in transmission oil pump would break due to harmonics vibration from PTO drive line. In the case I had it too was a gyro type mower being used when failure occurred. The tractor involved was a 50 or maybe even a 55 series. The fix was a new gear set that was made from a stronger steel rather than a cast steel part. Contact a dealer to do a search on Detach cases as there was a fix for this problem ten or twelve years ago. Good Luck, DW
