24 volt 4020 question on lights
jd1010
11-22-2004 07:44:51
i have a 24 volt question, just hooking up the lights on a 1968 4020 with factory cab at the batterys i have 24.5 volts and at feed wire to the light switch i have a little over 19.5 volts. this has a one wire 24 volt prestolite alternator on it with a built in regulator generator and regulator was taken off. now why do i have over 19 volts at my light switch how do i get it down to 12? what is wrong? what can i do to fix it? any help would be greatly appreciated. thanks in advance Jason
txblu
11-22-2004 11:33:04
 Re: 24 volt 4020 question on lights in reply to jd1010, 11-22-2004 07:44:51
Totally agree with Bob. BUT. You said you have 24.5 and it drops to 19.5 in getting to the switch. BIG problem. Wire too small..... should be getting hot if you run your lights for any length of time.
What you might want to do is what Bob said plus install a separate light switch:
You have 2 lights on each side looking forward. Each bulb is either 35 or 55 watts (12volt rating). Let's use the 55 number (taking the larger to be on the safe side).
So on one side of the tractor, you tie one bulb terminal (of each bulb) to ground. Daisy chain the other bulb terminals (on that side) and run a wire to the lights on the other side of the tractor. That puts 2 lights in parallel ready for the application of 12v on the starting side of the tractor. That wire is carrying 55watts x2 bulbs/12v = 9 amperes. 14 AWG is ok.
Take that wire to the other side of the tractor and tie to one bulb terminal of each bulb (daisychained again). Daisy chain the other side of these (2) bulbs together and run another 14 AWG wire to a separate toggle switch mounted on the removable switch plate between your legs opr wherever you want to mount your light switch.
Now you have a second pair of parallel bulbs ready for another 12v of applied voltage, stacked on top of the original 12v, ready for your 24v power source.
Get a switch rated for 28vdc and 10 amperes LAMP LOAD, with a rubber sealed toggle (keeps water out) if you can get one. Tie the other side of the switch to your 24.5 volt source.
But since you said it's only 19.5, continue from other side of this new switch to a 15 amp inline fuse (with your 14 AWG wire) and then on to the +24 volt battery terminal.
The switch: I looked and can't find a Single Pole, Single Throw (SPST) for a 10 amp lamp load but found one for a 5 amp lamp.....so if we go to a Double Pole (DPST) we can wire both sides in parallel (daisy chain the terminals together like you did the lights, for a total of 10 amps(This corresponds to a resistive load of 20 + 20 amperes on some switch ratings). You're talking about a heavy duty switch; not something you'll find in wally world.
Allied Electronics Co. (Used to be Allied Radio Corp) (800-433-5700) www.alliedelect.com (out of Chicago) has just the switch rated rain proof and the lamp load you need. Meets Mil Spec MIL-S-3950.
Allied Part Number: 826-8449, $28.92 each. Page 901 of their 2002/2003 catalog. Lotta money, but this switch will probably be there when you're pushing up dasies. And if your 10 miles from home at 10pm headed for the house and your lights quit..... ..... ...
I don't like using the original JD switch as you are applying twice the voltage it would normally see and who knows how old it is.....how reliable is it?
Gotta be careful getting switches for lights (lamp loads). The resistance of a light is about 1/10 cold as it is hot. A resistor is constant. Most switches are rated for resistive loads.
With the low resistance cold lamp, the inrush current to the lamp when you turn it on is 10x normal (90 amperes in your case) for the split second it takes for the filament to get hot and the current to drop to normal. This current inrush is hard on switch contacts even though it only lasts for a short period. Hence the heavy duty lamp load rated switch.
Good luck,
Mark
Gerald J
11-22-2004 20:42:59
 Re: 24 volt 4020 question on lights in reply to txblu, 11-22-2004 11:33:04
Close, but the resistance change for a tungsten filament lamp is closer to 16 times than 10 times. So the inrush current is 16 times as much as the operating current unless limited by the external circuit. The resistance of wires selected for carrying the operating current could well limit the inrush to 10x.
In 12 volt systems you generally want to select the wire size by voltage drop which often requires a larger conductor than NEC current ratings.
Gerald J.
txblu
11-22-2004 14:38:59
Quick update. Got home and measured lights of the front of a MF tractor. Were 55w. So just guessing, but the 55w number I used in the calculations is probably correct.
Mark
HTR
11-22-2004 18:40:29
 Re: 24 volt 4020 question on lights in reply to txblu, 11-22-2004 14:38:59
What are you going to do with the single rear work light?
txblu
11-23-2004 06:27:14
 Re: 24 volt 4020 question on lights in reply to HTR, 11-22-2004 18:40:29
Har Har..... made me think on that one. Get a 24 volt bulb and wire in a separate switch. I like to be able to kill the rear light if it's not being used and have a separate switch for that and another for flashers too which drive me nuts if I don't have to have them on.
Or you could wire it in parallel with the lights you wired to chassis ground. Now you really have me thinking as you now have a 1.52 ohm load (3 lights) in series with a 2.3 ohm load (2 lights). Kirchoff says that the voltage distribution will then be: 14.45 for the two (bright as hell) and 9.54 for the 3 (somewhat dim). Think I will go with the second switch and the 24 volt bulb or add a 12v rear light making 2 and run off the separate switch.
(Sneaky rascal you) Grin.
Mark
John T
11-22-2004 11:24:22
1010, The way it originally used 12 and 24 volts was that the alternator and starter were two wire 24 volt units tied across the outermost + and - of two 12 volt batteries connected in series. Then to get twelve volts for lights and other 12 volt loads, the mid tie point of the two batteries (where joined in series) was bonded to frame ground. That way from ground to the outermost untied + and - of the different batteries there existed 12 volts (one pos ground other neg ground). Those outermost untied points are 24 volts across each other (went to alternator and starter) BUT ALSO GO TO the A and B (12 volt) inputs on the switch, from which the lights are fed which are 12 volts and have their one lead tied to frame ground.
You might be sure the alternator is tied to the two outermost battery (+ and -) ends and IS NOT tied to frame ground. Also make sure that the mid tie point (where batteries joined in series) has the jumper wire to frame, and then check for two (A and B) 12 volts feeds to the light switch. Its those 2 feeds which are supposed to get switched out to the 12 volt lights when ON.
Good Luck
John T
Bob
11-22-2004 11:56:18
 Re: 24 volt 4020 question on lights in reply to John T, 11-22-2004 11:24:22
If the alternator he has is, infact grounded to the case (as it well may be, if it's a replacement for another application), and he ties that center battery connection to the frame, he's gonna let ALL the smoke out of his electrical system, in a hurry!
John T
11-22-2004 13:26:54
 Re: 24 volt 4020 question on lights in reply to Bob, 11-22-2004 11:56:18
For sure Bob, he has to have a correct two wire UNGROUNDED 2 wire 24 volt alternator or it could indeed be smoke city.
John T
Bob
11-22-2004 09:09:16
That tractor left the factory with a split (into 2 - 12 Volt systems) 24 Volt system.
The center of the 24 Volt system (the crossover between the two batteries) was connected to chassis ground, and (+) 12 Volts and (-) 12 Volts was plumbed up to the light switch, each powering 1/2 of the lights, more or less, to spread the load evenly between the two batteries.
I suspect what is happened is that some ham-fisted "goober" of a "mechanic" has installed an alternator that has the (-) side internally grounded to the alternator case, and from there to chassis ground, creating a true 24 Volt system rather than the original "split" system.
You can bring 12 Volt power from the center connection of the 2 batteries (as it's hooked up now) up to the light switch, connecting it to both the B1 and B2 terminals. This will work, more or less, but will take all it's current from only ONE of the batteries, which, if the lights are used for long periods, will drain that battery, and overcharge the other battery.
A couple of ways you could fix it... get the correct type of alternator, or hook up the lamps in pairs, in series. Your sealed beam tractor lights have two terminals on each bulb, and connecting 2 identocal part number bulbs in series will allow them to operate on 24 Volts.
Gerald J.
11-22-2004 10:57:05
 Re: 24 volt 4020 question on lights in reply to Bob, 11-22-2004 09:09:16
You could replace all the 12 volt lamps with 24 volt lamps. You have some wiring problems if you have 4.5 volts drop from battery through light switch, but if you are running the lights at that point you have excess current and very short lamp life.
Gerald J.
jd1010
11-22-2004 13:36:49
 Re: 24 volt 4020 question on lights in reply to Gerald J., 11-22-2004 10:57:05
thanks for all your help guys, i think what ill do for now and try is im only going to use the lights when there is snow to clean out of the driveway so ill run the 2 wires to b1 and b2 off the two posts wired in series. Then this coming summer switch it back to original. thanks again Jason
