4430 Cranks Slow
Tim A.
11-21-2004 19:47:41
Usually on first start attempt, the engine cranks over what seems to be normal speed for several seconds, then suddenly starts cranking over at about half speed. After a couple of start attempts, the left negative battery terminal (terminal protector spray started bubbling)and solenoid appeared to be getting hot. Checked the battery voltage with the batteries in the tractor and each checked at slightly above 6 volts and total voltage checked at about 12.5 volts. I also cleaned all battery terminals. Just purchased this tractor a short while ago. I suspect the solenoid, but it does appear to have been recently changed. My neighbor suspects the windings in the starter. Any suggestions would be greatly appreciated.
Thanks in advance!
Tim A.
11-22-2004 17:36:57
 Thanks for the help! in reply to Tim A., 11-21-2004 19:47:41
Thanks for all the advice. Removed the batteries today and am charging them now. With full charge, I will get them load checked tomorrow. The cables do not look in the greatest condition, although I have seen worse. Will consider replacing them. Removed the starter (that rear nut was a bear!!) and had it checked today. The solenoid post and starter post were both loose, apparently tightened incorrectly when the new solenoid was installed. In addition to making a poor connection, this wore out the insulator grommet at the starter post and allowed it to short. Also, there was another minor short inside, otherwise the starter was in real good condition. 30 minutes and $25 later, I was off to battle with that rear nut again!! Should be in good shape now. If I do replace the cables, how do I go about replacing the crossover cable...may not be too easy under the cab...
Thanks again,
Tim
G/MAN
11-23-2004 07:49:35
 Re: Thanks for the help! in reply to Tim A., 11-22-2004 17:36:57
The crossover cable isn't too bad. Pulling the little covers below the door and access door can make it somewhat easier. If you need new batteries, I'd strongly consider making the change to two 12-volt batteries in parallel. It requires new cables, but will make a world of difference in cranking power.
txblu
11-23-2004 06:37:23
dunno on the crossover cable. AS stated. Put my batteries right next to the starter.
When you do replace them, get size AWG 00. Won't be sorry.
Mark
G/MAN
11-22-2004 07:34:12
 Re: 4430 Cranks Slow in reply to Tim A., 11-21-2004 19:47:41
Fully charge and load test your batteries. Fully-charged batteries should have around 2.2 volts per cell, or around 13.2 total no-load volts for two 6-volt batteries in series. If you're at 12.5 with no load, your batteries are somewhat discharged and are dropping off quickly.
Bob
11-21-2004 23:42:06
Where you have "HOT" connections, there is a POOR high-resistance connection. Take those connections apart and shine them up. There is no reason, except for a poor connection, for a specific connection to heat up during cranking. If only one battery post is getting hot (not all 4), there is definitely a problem with the one that's heating up... dirty cable end or battery post, battery cable terminal that's not crimped or soldered tight inside, to the cable, or even a bad connection inside the battery, at the bottom of the terminal.
Sometimes the Deere crankshaft-driven hydraulic pumps will go into stroke and build hydraulic pressure while cranking, making it tougher for the starter turn spin the engine over.
Try turning the steering wheel from side to side while the engine is cranking, to relieve some hydraulic pressure, and see if this helps.
Deere does make an "electric destroke kit" that keeps the front pump from working during cranking.
buickanddeere
11-22-2004 14:11:56
 Re: 4430 Cranks Slow in reply to Bob, 11-21-2004 23:42:06
Amen.
RJS
11-21-2004 20:33:21
I have a4440and checked the book,it said thatyou should not crank engine starter for more than 30 sec.and allow 2 minutes after for cooling and battery recovery.with that said,I would check your cables and have your batteries load checked.if they check ok,take a look at the starter,there may be a reason the solinoid was replaced.the book gives a 90to130amp no load amp [email protected] there hammer marks on the starter motor?if so,there could be internal dammage.if the starter checks ok you may have some internal problems [engine or trans?] my experience with the"30"series is that they are hard starters,and exessive heat in the starting circuit is your worst enemy.Ihope this helps.
Tim A.
11-21-2004 20:45:59
 Re: 4430 Cranks Slow in reply to RJS, 11-21-2004 20:33:21
My book says the same...30 sec for 4 attempts then allow for cool down etc. 30 sec seems like forever and I am sure I have not cranked it more than that. Also, the tractor runs and shifts like a top so I don't suspect an internal problem. No hammer marks on the starter but it could still be faulty. Could the batteries still be faulty if they appear to be holding a charge??
txblu
11-22-2004 11:44:10
 Re: 4430 Cranks Slow in reply to Tim A., 11-21-2004 20:45:59
Batteries are funny critters. What they do with age is develop internal resistance. This resistance is series with your load and as the 100 amps is pumped out, a resistance in the battery as low as 0.1 ohm could drop 10 of your 12 volts leaving only 2 volts to be applied to the starter; or on a series battery setup 4 volts for your starter.
You have to have your batteries "load checked" which forces them to put out high current and then checks the voltage drop across them.
I'd say at 100 amps, if your battery terminals don't read at least 11 volts, you have internal problems.
Then you have to get that 100 amps to the starter and the same rule of resistance applies to the wires and connections including the copper contacts within the solenoid.
Once you get hopefully 80 to 90% of your battery voltage to the starter terminals (at 100 amps) your starter still has to get the current into the stator thru the brushes so there is still room for sluggish operation.
Auto Zone can check your batteries. Just because your wiring and connections look good means nothing. Get a voltmeter and follow your voltage while cranking. If you loose 1 or 2 volts across a piece of cable or a connection, it's bad...period.
HTH.
Mark
