JD 2640 want move
Vern
11-21-2004 19:04:56
I got a 2640 tractor that some of the time when you back up and then go forward it would not move forward play with it awhile and hit the brakes and then it would go,but it didn't act like it was a brake holding. Now it won't move at all,put it in gear and let out on the clutch and it just sits there.It has the standard 8 speed transmission without the reverser or hi lo. Any advice on where to start at would be appreciated. Thanks
david val
11-22-2004 03:44:50
 Re: JD 2640 want move in reply to Vern, 11-21-2004 19:04:56
probably the clutch slipping. make sure you have about 1 inch free movement at the clutch pedal.
david
