60 CARB
MDM
11-20-2004 18:08:24
I HAD A NEW KIT PUT IN THE CARB ON MY 60. CAN ANYONE HELP ME GETTING IT SET? RUNS FINE AT 1/4 THROTTLE AND ABOVE, SPITS AND SPUTTERS AT IDLE.
gusc
11-20-2004 22:22:53
 Re: 60 CARB in reply to MDM, 11-20-2004 18:08:24
To add to chuck's remarks, remove the two idle screws, stick the plastic nozzle of a spray can carb cleaner into them and give them a good squirt. Then set the screws at the number of turns out as prescribed in the 60 Manual. You do have a manual?
ChuckW
11-20-2004 19:32:14
sounds like your idle ports are somewhat clogged. I would suggest looking at a carb diagram and you can see what needs to be cleaned.
