'43 'A' lives again!
JDF
11-20-2004 18:06:19
Between work and other things we have almost got her finshed. I put a fresh coat of paint on her, put in new gauges, spark plug wires and front tires. I overhauled the carb, it is a DLTX 51. Today I finally got around to starting her up. It started and ran great. While it was running, "I noticed that the governor will not let it idle down. My Question is, what can cause this?
Any help in this matter will be greatly appreciated!
JDF
Earl S
11-20-2004 19:17:28
 Re: '43 'A' lives again! in reply to JDF, 11-20-2004 18:06:19
Cotter key on end of throttle rod at carb butterfly can be dragging on carb.
Duane Larson
11-20-2004 18:54:40
JDF,
First, your carburetor should be a DLTX53 - a 51 is for a GM or a G. If it is indeed a 51 that could be a contributing factor.
However, the rod running from the governor spring to the carb butterfly needs to be the correct length. To check this, unhook the rod at the butterfly by removing a cotter key, then push your hand throttle full forward to the stop and rotate the carb butterfly to the wide open position (the butterfly will rest against the stop pin). Under these conditions the rod should be 1/2 hole short of going in the butterfly - ie, the rod will need to be pulled (against the governor spring) 1/2 of the hole width in the butterfly to put it in place. If this distance is not correct, there is an adjustment for the length near the governor spring.
Finally, the carb load and idle needles should be open about 1 turn each as a starting point.
