4010 hydraulic pump
Steve
02-09-2004 16:47:48
The hydraulic pump on my 4010 has been leaking for some time and I think the time has come to change it. I've got the wide front end out from underneath it and plan to try to get the pump out tomorrow. Any advice? It doesn't look too bad. I guess the main thing I was wondering about was what to do with the pump when I get it out. The parts man sounded like parts for a complete rebuild could be in the neighborhood of $600. Does this sound about right? I think he said that I could get a remanufactured one for around $1000 with exchange. If this is accurate I think I will go with the remanufactured one. It has a one year warranty. What do you guys think?
Paul
02-10-2004 06:04:31
 Re: 4010 hydraulic pump in reply to Steve, 02-09-2004 16:47:48
Might also want to check into larger pump original 4010 pump was 2.3cubic foot 4020 was 3 cubic foot. I did this to my 4010 made a world of difference for loader work Paul
Karen
02-10-2004 03:01:47
I know someone that sells quality rebuilts. They come from same place as Worthingtons and they will discount them. E mail me and I will send you their email address
doug@upr
02-09-2004 17:33:28
if i were you, and i'm not, i would go with a reman pump from worthington, though i believe they only come with 6 month warranty, they have rebiult over 10,000 pumps.
as for only needing a seal kit, that is usually not the case, since one of the main reasons these pumps leak, and leak after cheap rebiulds is because of the reusing of worn shafts, that people feel will pass with new seals, also other items become worn such as inlet valves & seats, destroking valve, one more important item to consider is if your pump is original to your tractor then your pump does not have the secondary bleed of line, that allows oil to bleed back to the trans. since all of reman pumps usaully come with this feature, all you have to do is plumb it into your rearend. in short the best buy is to purchase one from your local worthington store, up here in canada we have been selling their pumps for about 10 years with very little problem.
mike
02-09-2004 17:17:39
if you decide to rebuild it your self if it is 4010 pump it will use a different seal than the one in your kit from jd, read the info with your kit and it will give the part number for 3010,4010,5010 seal , why spend 600, 700 for nothing more than what you got with some new brgs asnd seals.
Brokenwrench
02-09-2004 17:00:45
If you take the pump apart and it is showing minimal wear,and the hydraulics were functioning properly,aside from the leak,a seal kit is about $70.00. Instructions for resealing it are in the kit. It's not a bad job,just keep everything clean and in order, take your time and save yourself $500.00-$800.00
thurlow
02-09-2004 16:58:22
I've had real good luck with re-manufactured pumps from Worthington; been 2 or 3 years; seems like they were in the $600 range.....
Steve
02-09-2004 19:20:32
 Re: Re: 4010 hydraulic pump in reply to thurlow, 02-09-2004 16:58:22
Can anyone tell me how to get in touch with Worthington? Do they have a website. A toll free number? I think I will be going with a rebuilt pump. I'd hate to go to all the trouble of taking this thing out putting some seals in and then have it still not working properly. Thanks. Steve
