530 3 pt interchange with?
Joe S
11-19-2004 15:35:46
Will any of the 30 series 3 pts interchange on a JD 530??
I Bleed Green
11-19-2004 15:48:37
 Re: 530 3 pt interchange with? in reply to Joe S, 11-19-2004 15:35:46
Yes. 520, 620, 720, 530, 630, and 730 have the same 3 point hitch.
Tyler-MO
11-20-2004 08:08:04
 Only 520, 620, 630 in reply to I Bleed Green, 11-19-2004 15:48:37
The 720 and 730 tractors of any configuration will not work. The rockshaft arms are clocked differently and the lower "elephant ears" or cast iron brackets do not match up with the 6xx and 5xx series tractors. The center link is exactly the same for all 520, 30, 620, 630, 720, 730 however. If you have any more specific questions please post back or email me and I"ll be glad to assist. Tyler in Missouri
Ray
11-19-2004 17:30:00
 Re: 530 3 pt interchange with? in reply to I Bleed Green, 11-19-2004 15:48:37
The 730 won"t fit a 530.
Joe S.
11-19-2004 15:52:45
I tip my JD hat to you the info thanks.
Mike M
11-19-2004 15:51:13
The 720,730 models take different elephant ears / or the big cast mounting pieces to the tractor than the others.
lloyd sc
11-20-2004 20:06:20
 Re: 530 3 pt interchange with? in reply to Mike M, 11-19-2004 15:51:13
As the 1010 is a "530" back 1/2, do they fit in here as well? thanks
Mike M
11-21-2004 07:03:45
 Re: 530 3 pt interchange with? in reply to lloyd sc, 11-20-2004 20:06:20
No . It is more closely like a model 430.
