Compression test on a 46 B all Fuel
Kromko
11-19-2004 09:44:54
The compression test shows 30 on one cylinder and 40 on the other. What should it be is my question?
Earl S.
11-20-2004 08:23:05
 Re: Compression test on a 46 B all Fuel in reply to Kromko, 11-19-2004 09:44:54
I&T manual 70lbs at cranking
John T
11-19-2004 13:00:12
Kromko, Thats a bit low, plus the difference between the two cylinders isnt a great thing, ESPECIALLY if thats a wet test with some oil on the rings n cylinders??? The next question, is most of the leakage due to valves or rings??? To some extent you can answer that by bringing a piston up to TDC on compression then listening if theres blow by pressure leaking out the carb (leaky intake valve) or out the exhaust (leaky exhaust valve) or out the crankcase (rings). Another question for ya !!!! Make sure the valve lashes are correct also so they are closing fully and are indeed at least going open n closed and none are stuck??
If shes sat a long while and it appears theres blow by past the rings (maybe they are stuck n carboned up) and she throws some blue smoke out the stack, you may wanna consider changing the oil and refilling with a quart of Rislone and a quart of Auto Tranny Fluid and 10W30 detergent oil and use her long n hot n hard and see how she does??
Let us know, Good Luck n God Bless
John T
Mike M
11-19-2004 10:03:16
I seem to remember a figure of 75 lbs for an all fuel. I also think this is listed in an I&T manual. I think it's time for a valve job at the least.
