F-I-T 70 Power Steering update
BAM BAM
11-18-2004 11:19:39
Frank,
Thanks for your input on going through my 70s Power Steering. As you recall I had some issues that others may benefit from.
1. Could not find a good part number for improved (headed) vane pin, so I used the original.
2. Stationary vane pin cracked in half, still available from JD, replaced with new part.
3. Pedestal bearing stamped thrust on what appears to be wrong side, had several others eye ball it, consensus was it was indeed mismarked, replaced worn original with new bearing side marked thrust up. FYI bearing was JD part, made in USA and aside from being mismarked appeared to be high quality.
4. My pedestal was never machined for the F 2278 bushing directly above the cylinder and vanes (Cloony indicated he had seen this also) , been that way for almost 50 years with no trouble, replaced seals and reassembled.
The unit works as new with no leaks or binding at all. Not too bad of a job to perform. I wouldn�t hesitate going through one again.
Again thanks,
Scott Davis
Mike M
11-18-2004 13:19:32
 Re: F-I-T 70 Power Steering update in reply to BAM BAM, 11-18-2004 11:19:39
I was just curious,was the new bearing (thrust) mark in a different spot compared to the old one ? Like maybe one on the inside race and maybe one on the outside race on opposite sides. If this was the case they would end up being the same and having the load going the same way would they not ?
F-I-T
11-18-2004 12:04:41
Scott:
Good Deal!
Yup. Most are cracked because that pin is used as the stop on that side. Almost always cracked through.
Frank
