47A Valve Problem
JDABG
11-17-2004 21:19:11
Found valve lash about 1/3" on 1 valve, others are ok. I can adjust it in but just barely. What could cause this? What is on the other end of the pushrod? What type lifter rides the cam?
BushogPapa
11-18-2004 08:51:13
 Re: 47A Valve Problem in reply to JDABG, 11-17-2004 21:19:11
Sounds like a sticking valve..or something (Carbon??) stuck under the valve...
Strike the top of the valve stem with a brass tool to try to make sure the valve is really "on the seat"... Put some oil on the stem, at the guide so the oil will work into the guide when you do.. If that is the problem...set the valves, and when you run it next time..move it outside, and remove a line to allow you to squire a whole oil can of oil into the intake--with the engine running at a fast idle--to lube the valves.. It will smoke a great deal, but it does work..!!! We do this about once a year...
1945 A
11-18-2004 05:55:00
Another possibility, would be a bad camshaft bearing, or possibly loose or broken bolts securing the gear to the camshaft, which you could determine by pulling the crankacase cover, and trying to move the camshaft. You can also take a look at the left side bearing by pulling the cover.
Good Luck!
Lee B
11-18-2004 00:41:30
Stuck valve, or worn camshaft would sure do it. A barrel type cam follower (lifter, tappet) according to I&T manual for A"s is on the other end of the pushrod. It appears to be removable either forwards or backwards, but I"ve learned not to go by appearances in a parts manual. The pushrod should have a ball or rounded end that simply fits into a matching socket in the lifter.
Make sure your valve spring heights are all pretty much the same first, then pull that pushrod and see if it had a spot for a ball bearing at the cam end of it that maybe fell off? Still not finding anything, it"s time to take off the crankcase cover and feel the cam lobes and/or eyeball them with a mirror and trouble light in the crankcase.
