2440 diesel coolant drain plug
F/F
11-17-2004 18:22:59
I have a 2440 diesel I just bought and I want to drain the coolant and I am not sure where the drain for the block is located. Could any of you out there be of any help. I have the owners manual but it does not show the location. I found a plug on the right side near the front of the block with a square head, not sure if this is it or not. Thanks for your help.
F/F
11-18-2004 11:51:11
 Re: 2440 diesel coolant drain plug in reply to F/F, 11-17-2004 18:22:59
Thanks for the replies David and Walter. They did use the drain for the heater. We got it drained and new coolant installed, again thanks for the help.
david val
11-18-2004 03:47:21
the drain tap (the same as the one on the radiator), is located at the left side of the engine at about injection pump level and about 6 to 8 inchs from the rear of the engine
walter squires
11-18-2004 07:00:21
 Re: 2440 diesel coolant drain plug in reply to david val, 11-18-2004 03:47:21
If it had an external engine block heater installed they sometimes tap into the block drain. that might be why you cant find it.
Yes it is on the left side.
