J.D. AR Styled Questions
Tom Beasley
02-09-2004 14:35:56
Hello, I have 2 questions about the AR tractors. My first question is, Were the power blocks ever installed in the AR ? If so what years ? My second question, What is the best year AR to own ? I think they are a neat old tractor and had to ask. thanks Tom
bent
02-10-2004 14:28:40
 Re: J.D. AR Styled Questions in reply to Tom Beasley, 02-09-2004 14:35:56
Tom, are you asking about the difference between early and later styled AR's or the difference between styled and unstyled? I know little about unstyled models. I do know that "live" hydraulics were available on AR's and AO's, referred to as "New Improved" or "styled" after serial number 272000 until 284074.
Dan
02-10-2004 11:01:11
That late styled AR also has live hydraulics like the first numbered series tractors do. That 53 Ar has a motor more like the 60 than the A (all except the carb).
bent
02-10-2004 07:59:36
I have both an early styled ('49 sn272765) and a late styled ('53 sn283713) The early one has no water pump and a magneto with no key. The later model has a water pump and a distributor and a key. The clutch on the early one uses 2 fibre disks while the later one uses 4. other than that, there is very little difference.
Mr Tinker
02-09-2004 19:03:46
TSC POWER-BLOCKS (not a JD product) were made for electric start A, B, G, 50, 60 and non deisel model 70 tractors. If your AR tractor uses the same block as an "A" tractor, it will fit. The late styled AR ('49 thru '53) requires a No. 3 POWER-BLOCK. If you are talking unstyled AR then a No. 1 is required. Hope you can find one, they are getting about as scarce chicken lips!
