FLAT TOP FENDER LIGHTS.
LUKE ERPELDING
11-16-2004 17:00:28
I AM INSTALLING AFTERMARKET FLAT TOP FENDERS ON MY 530. IS THER 2 LIGHTS ON EACH SIDE AND WHAT TYPE OF LIGHTS? WILL I NEED TO REMOVE THE OTHER ORIGINAL LIGHTS ON TRACTOR? THANKS LUKE
CLW
11-16-2004 17:31:08
 Re: FLAT TOP FENDER LIGHTS. in reply to LUKE ERPELDING, 11-16-2004 17:00:28
The fenders have two lights per side. The inner light is a spot and the outer is flood. You can get the aftermarket original looking lights from suppliers found in GM or 2-Cyl. mag. You can get lights from Deere that work and are brighter than the original but they won't look like original. So it depends on how original or how practical you want to be. You can remove the lights that are on it to be correct or leave them for more light. The parts book on my 630 shows the same Ign. switch for two or four lights so yours should be OK. If you need a wiring diagram when you get your lights I can send you one.
CLW
