JD 50 with 15.5-38 rears
Tye
11-16-2004 06:42:28
I am thinking about putting on some new tires that are better for pulling. I have a stock JD 50 that runs great. Does the stock engine have enough power to turn the 23 degree bar 15.5-38s on a pullling track?
Bushogpapa
11-16-2004 22:59:27
 Re: JD 50 with 15.5-38 rears in reply to Tye, 11-16-2004 06:42:28
I have 15.5x38" tires on my 520 and think they are "Perfect"....!! I do a lot of low-land mowing and need the floatation..they are loaded about 1/2 capacity... I have no problem turning them if I get a good load on the tractor...Pulling trees, etc...
buickanddeere
11-16-2004 08:23:22
Creeper gear and stock HP, yes. Shorten that drawbar all the way in and be ready to hang weights on the front. The last time I pulled the non power steering 50 in the 5500lb class on a sticky track. Lifting the front and therfore dropping the drawbar was a problem. Makes the souped tractor guys with three times the power mad when the 50 places in the top three.
Loren-MN
11-16-2004 22:50:49
 Re: JD 50 with 15.5-38 rears in reply to buickanddeere, 11-16-2004 08:23:22
buickanddeere,
I know you name but can't remember it right now. I've got a 1955 Model 50. First tractor I did a full restore on. I've never considered pulling with it. Just never thought it had enough nuts!! Maybe I should re-consider???
Loren-MN
Tye
11-16-2004 10:18:44
Thank you very much for your advice and insight. Have a great day!
