8520 with climatrak
billyiron
11-15-2004 20:22:48
have a 8520 with the climatrak auto heat-cool system,,it had new brains put in last spring,but all it will do is give you heatstroke or frostbite,,,anybody got the fix for this,,,,, ,,,we have a 8120 a year newer and it works good, can the 8520 be upgraded to that style----- -----billyiron
JDGnut
11-16-2004 18:19:52
 Re: 8520 with climatrak in reply to billyiron, 11-15-2004 20:22:48
I'm guessing the 8520 has the old style climatrak system.. that has the little red light??? and the 8120 has the newer style with the little LCD display... No the old can not be upgraded, within any reason... (have to change the wiring in the cab.. controllers.. and big bucks..) Does the little red light flash all the time??? This means there is a code (problem in the Climatrak system) This will continue to flash until the problem is fixed.. once it is fixed.. it will quit flashing... To recal the codes for the older Climatrak.. insert the spare F9 (10amp) fuse into the F10 slot, turn the key on.. and count the flashes.. there will be one long flash..(that is indicating the starting of the codes.) then the code will start flashing.. there is only 8-9 codes.. there there will be another long flashing (indicating the end of the codes. )if there is a pause and more flashes.. there is more than one code.
It could just need the Temp Pot recalibrated, a sticking heater valve or a bad sensor... Let me know if you have a code... this will give us a starting place... JDGnut
billyiron
11-16-2004 21:14:21
 Re: 8520 with climatrak in reply to JDGnut, 11-16-2004 18:19:52
Thanks for responding,,Nope, no red light flashing,,on the 81 you get heat without air conditioner on,,the 85 needs to have air on to get any heat,is that normal,,,billy
JDGnut
11-17-2004 11:28:53
 Re: 8520 with climatrak in reply to billyiron, 11-16-2004 21:14:21
Drop me an email.. or give me your address.. and I'll send you some charts that will tell you what should be on when... JDGnut
